Попробовал набросать метод замену. Расположил в классе Session. X++: /// <summary> /// Splits the given String by the specified separator and returns the contents in a container. /// GRD_Stuff_pkoz, Перенос "наработок" из 2009-й, pkoz, 22.11.2015 /// </summary> /// <param name="_value"> /// The String value to be split. /// </param> /// <param name="_sep"> /// The separator. /// </param> /// <param name="_convertNumericToInt64"> /// A Boolean value that indicates whether to convert the value to an <c>int64</c> value; optional. /// </param> /// <param name="_unpackLineNumber"> /// A Boolean value that indicates whether to extract line number from stacktrace string _value; optional. /// </param> /// <returns> /// A container, which has the String split by the specified separator. /// </returns> /// <remarks> /// In the <paramref name="_convertNumericToInt64" /> parameter, a value of true indicates the returned /// contents will be converted to an <c>int64</c> value if they only have numeric characters.A value of /// false indicates that the returned values will not be converted to an <c>int64</c> value and String /// values will always be returned. The default value of the <paramref name="_convertNumericToInt64" /> /// parameter is true. /// </remarks> static container stackLine2con(str _value, str 10 _sep = ',', boolean _convertNumericToInt64 = true, boolean _unpackLineNumber = false) { int length = strLen(_value); int separatorLength = strLen(_sep); int i = 1; int j = strScan(_value, _sep, 1, length); container ret; void add2Ret(str _current) { if (_convertNumericToInt64 && (match('<:d+>', _current))) { ret += str2int64(_current); } else { ret += _current; } //GRD_Stuff_pkoz, Перенос "наработок" из 2009-й, pkoz, 22.11.2015 --> if ( _unpackLineNumber ) { ret += 0; // пока не реализовано } else { ret += 0; } //GRD_Stuff_pkoz, Перенос "наработок" из 2009-й, pkoz, 22.11.2015 <-- } while (j) { add2Ret(subStr(_value, i, j-i)); i = j + separatorLength; j = strScan(_value, _sep, i, length); } add2Ret(subStr(_value, i, length-i+1)); return ret; } /// </param> /// <param name="_mode"> /// An Int value that indicates how to convert the value to container; optional. /// </param> /// <returns> /// A container, which has the stack trace. /// </returns> /// <remarks> /// /// </remarks> client server public static container xppILCallStack(int _mode = 0) { str stack; container ret; // int startPos; #define.delimiter(" at ") ; if (!xSession::isCLRSession()) return xSession::xppCallStack(); new InteropPermission(InteropKind::ClrInterop).assert(); stack = System.Environment::get_StackTrace(); // startPos = strScan(stack, #delimiter, 1, 1000); switch (_mode) { case 0 : // режим, похожий на обычный xSession::xppCallStack() только извлечение номеров строк не сделано ret = [ (isRunningOnServer() ? "(S)" : "(C)") + "(CIL)", _mode ] + Session::stackLine2con(stack, #delimiter, false, false); break; case 1 : // быстрый режим, чтобы не тратить процессорное время на обработку строк. Использующий код в дальнейшем сам обработает как надо - распакует и.т.п. А скорее всего просто проигнорирует. ret = [ (isRunningOnServer() ? "(S)" : "(C)") + "(CIL)", _mode ] + [stack, 0]; break; } return ret; } Кто как решает проблему получения стека вызовов при исполнении в p-code и CIL ? Последний раз редактировалось Logger; 23.11.2015 в 12:40. Причина: исправил ошибки |
| За это сообщение автора поблагодарили: Ace of Database (5). | |
| Теги |
| callstack, debug, debug code, debug managed code, mfp, stack trace, законченный пример, полезное |
