Старый 13.08.2010, 21:06   #1
sumitax: EP Debugging Tips and Tricks –Part I
Источник: http://sumitax.wordpress.com/2010/07...tricks-part-i/
While EP Debugging in Windows 2003 Server (64 bit machine), if you use the following command to attach the wswp.exe process (IIS Worker Process )from Visual Studio, you will get the error “System can not find the file specified” even though the  iisapp.vbs file exists in C:\Windows\System32 folder.
Cscript.exe  iisapp
Remember to add the extension .vbs to iisapp command  file to fix this issue. The correct way is :
Cscript iisapp.vbs
Solutions Monkey: EP Tips-n-Tricks - Data Sets / Data Sources Blog bot DAX Blogs 0 05.01.2010 19:16
Solutions Monkey: Convergence session: Enterprise Portal Deployment Tips and tricks Blog bot DAX Blogs 0 26.03.2009 08:05
Solutions Monkey: Microsoft Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks – 3 Blog bot DAX Blogs 0 27.10.2008 08:05
Solutions Monkey: Microsofty Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks - 2 Blog bot DAX Blogs 0 30.09.2008 07:07
Solutions Monkey: Microsofty Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks - 1 Blog bot DAX Blogs 0 26.06.2008 09:05
Часовой пояс GMT +3, время: 07:49.
