Старый 30.09.2010, 09:05   #1
sumitax: EP Debugging Tips and Tricks –Part II
Источник: http://sumitax.wordpress.com/2010/09...%80%93part-ii/
For EP Debugging on Windows Server 2008 R2 , make sure the following is set up in web.config for Debugging in VS2008 to work :
  1. In the Compilation tag , debug attribute should be set to true.
  2. In Customerrors tag mode attribute should be set to off.
Note: As an alternative to hand editing this file you can use the
  web admin tool to configure settings for your application. Use
    the Website->Asp.Net Configuration option in Visual Studio.
sumitax: EP Debugging Tips and Tricks –Part I Blog bot DAX Blogs 0 13.08.2010 21:06
Solutions Monkey: EP Tips-n-Tricks - Data Sets / Data Sources Blog bot DAX Blogs 0 05.01.2010 19:16
Solutions Monkey: Convergence session: Enterprise Portal Deployment Tips and tricks Blog bot DAX Blogs 0 26.03.2009 08:05
Solutions Monkey: Microsoft Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks – 3 Blog bot DAX Blogs 0 27.10.2008 08:05
Solutions Monkey: Microsofty Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks - 2 Blog bot DAX Blogs 0 30.09.2008 07:07
Часовой пояс GMT +3, время: 04:08.
