Старый 11.07.2013, 14:21   #28
MikeR is offline
MikeR
MCT
Аватар для MikeR
1,628 / 627 (24) +++++++
Продолжаю копать дальше -
При вызове N-1000 по логу формируется файл
(10884)	[32]	CCriticals::GetInstance
2013.7.11 13:50:21:736	(10884)	[32]	CCriticals::CreateTempFile
2013.7.11 13:50:21:737	(10884)	[4]	CCriticals::CreateTempFile: Create a temp file called 'C:\Users\......\AppData\Local\Microsoft Dynamics AX\60\Commerce Data Exchange\Synch Service\AXAOS....\work\AXAOS...-82-I.tmp'
2013.7.11 13:50:21:756	(10884)	[4]	CCriticals::CreateTempFile: Successfully created temp file 'C:\Users\......\AppData\Local\Microsoft Dynamics AX\60\Commerce Data Exchange\Synch Service\AXAOS...\work\AXAOS...-82-I.tmp'
2013.7.11 13:50:21:759	(10884)	[32]	CStlStream::Open
2013.7.11 13:50:21:759	(10884)	[2]	CStlStream::Open: Trying to open C:\Users\...\AppData\Local\Microsoft Dynamics AX\60\Commerce Data Exchange\Synch Service\AXAOS....\work\AXAOS...82-I.tmp for writing
2013.7.11 13:50:21:762	(10884)	[8]	CStlStream::Open: Successfully opened C:\Users\.....\AppData\Local\Microsoft Dynamics AX\60\Commerce Data Exchange\Synch Service\AXAOS...\work\AXAOS....-82-I.tmp
2013.7.11 13:50:21:762	(10884)	[2]	CTransMgr::ReadFile: Successfully opened temp file 'C:\Users\.....\AppData\Local\Microsoft Dynamics AX\60\Commerce Data Exchange\Synch Service\AXAOS...\work\AXAOS....-82-I.tmp'
2013.7.11 13:50:21:764	(10884)	[4]	CSocketConnection::WaitForData: Command = TYPE_MSG
2013.7.11 13:50:21:764	(10884)	[32]	CCriticalItem::Update
2013.7.11 13:50:21:764	(10884)	[32]	CCriticals::GetInstance
2013.7.11 13:50:21:764	(10884)	[32]	CCriticals::IncActivityCounter
2013.7.11 13:50:21:766	(10884)	[32]	CStlStream::Write
2013.7.11 13:50:21:768	(10884)	[2]	CTransMgr::ReadFile: Wrote 3557 bytes to stream
2013.7.11 13:50:21:768	(10884)	[4]	CSocketConnection::WaitForData: Command = TYPE_CMD.CMD_DATAEND
2013.7.11 13:50:21:768	(10884)	[2]	CTransMgr::ReadFile: Wrote a total of 3557 bytes to stream
2013.7.11 13:50:21:768	(10884)	[32]	CCriticalItem::Update
2013.7.11 13:50:21:768	(10884)	[32]	CCriticals::GetInstance
с таким наполением
<?xml version="1.0" encoding="utf-8" ?>
- <Microsoft.Dynamics.Retail.StoreConnect.Request.AXHandler.SCAXSourceRequestHeader>
  <PartitionID>5637144576</PartitionID>
  <JobID>N-1000</JobID>
  <DataAreaID>x5</DataAreaID>
  <DataProcessingClassName />
- <DeleteOnTargetRequests>
- <SCDeleteByFilterRequest>
  <TargetTableName>CURRENCY</TargetTableName>
далее идет перечисление полей
и запросы
 <Query>SELECT * FROM %1 WHERE 1==1</Query>
<Query>date dt1=01\01\1900; date dt2=31\12\2154; SELECT validTimeState(dt1,dt2) * FROM %1 WHERE 1==1</Query>
То есть берутся все записи, да и есть упоминание о байтах...
Но в базу магазина не попадают.
Axapta book for developer
Последний раз редактировалось MikeR; 11.07.2013 в 14:29.
retail, ax2012
emeadaxsupport: AX for Retail 2012 R2: Adding a Custom User Control to the POS Blog bot DAX Blogs 0 27.02.2013 07:14
emeadaxsupport: AX 2012 R2 for Retail - Setting up discount coupons with bar codes for scanning into POS Blog bot DAX Blogs 0 26.01.2013 09:12
emeadaxsupport: AX for Retail 2012 R2: Installing the Real-time Service Blog bot DAX Blogs 0 19.12.2012 11:11
emeadaxsupport: Final Microsoft Dynamics AX 2012 R2 Content Available! Blog bot DAX Blogs 0 04.12.2012 06:12
emeadaxsupport: Preliminary Microsoft Dynamics AX 2012 R2 content now on TechNet and MSDN! Blog bot DAX Blogs 0 10.11.2012 08:20
Часовой пояс GMT +3, время: 16:17.
