Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 24.11.2012, 00:08   #1
Kent is offline
Kent
Query ranges OR condition
Hi,
The following code sample:
Query q = new Query();
QueryBuildDataSource qbds;
qbds = q.addDataSource(tablenum(Table1));
SysQuery::findOrCreateRange(qbds, fieldnum(Table1, Field1)).value(a);
SysQuery::findOrCreateRange(qbds, fieldnum(Table1, Field2)).value(b);
Both ranges for Field1 and Field2 works as AND expression.
Is it possible somehow handle those ranges as OR expression, between those fields?
Старый 24.11.2012, 12:21   #2
MikeR is offline
MikeR
MCT
Аватар для MikeR
1,628 / 627 (24) +++++++
AND and OR clauses
This example will help you.
You may use both clauses in one expression.
queryBuildRange.value(strFmt('((%1 == %2) || ((%1 == %3) && (%4 == "%5")))',
    fieldStr(InventTable, ItemType),
    any2int(ItemType::Service),
    any2int(ItemType::Item),
    fieldStr(InventTable, ProjCategoryId),
    queryValue("Spares")));
Axapta book for developer
Старый 24.11.2012, 17:08   #3
Kent is offline
Kent
Thanks
Старый 24.11.2012, 18:14   #4
Kent is offline
Kent
Сообщение от MikeR Посмотреть сообщение
But it seems, it works only for enum type fields...
Старый 24.11.2012, 20:30   #5
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
That's not quite correct, it works for other field types, too, but you have to format literals in a slightly different way. E.g. string literals must be enclosed in double quotes and dates must be formatted in X++ way (yyyy\mm\dd).
Старый 24.11.2012, 22:09   #6
Kent is offline
Kent
Hi, I tried, but without result:
QueryRun qr;
QueryBuildRange qbr;
CustTable custTable;
qbds = q.addDataSource(tablenum(CustTable));
qbr = SysQuery::findOrCreateRange(qbds, fieldnum(CustTable, AccountNum));
qbr.value(strfmt('((%1 == %2) || (%3 == %4))',
fieldStr(CustTable, AccountNum),"000015",
fieldStr(CustTable, InvoiceAccount),"000023"));
qr = new QueryRun(q);
if (qr.prompt())
while (qr.next())
custTable = qr.get(tablenum(CustTable));
info(strfmt("AccountNum: %1; InvoiceAccount: %2", custTable.AccountNum, custTable.InvoiceAccount));
Старый 24.11.2012, 22:23   #7
gl00mie is offline
gl00mie
String literals must be enclosed in double quotes Try this:
qbr.value(strfmt('((%1 == "%2") || (%3 == "%4"))',
Старый 24.11.2012, 22:42   #8
Kent is offline
Kent
Yes, this is correct way. Whole hour looked at query and didn't sigth that nuance.
Thank You!
ax-erp: X++ Code to get the Ranges / Criteria from Query Blog bot DAX Blogs 0 12.06.2012 12:11
daxline: How to add empty ranges in query Blog bot DAX Blogs 0 28.06.2011 19:11
daxline: SysQuery::findOrCreateRange() - A better way to create dynamic query ranges Blog bot DAX Blogs 0 28.01.2011 23:14
jinx: Dynamics AX – Query-Ranges und Filtereinstellungen des Benutzers Blog bot DAX auf Deutsch 0 04.02.2010 00:05
paruvella: Dynamics Ax - Simple SSRS report example by using Ax-Query and Ranges Blog bot DAX Blogs 0 08.01.2010 16:05
Часовой пояс GMT +3, время: 16:28.
