Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 24.11.2012, 22:09   #6
Kent is offline
Kent
That's not quite correct, it works for other field types, too, but you have to format literals in a slightly different way. E.g. string literals must be enclosed in double quotes and dates must be formatted in X++ way (yyyy\mm\dd).
Hi, I tried, but without result:
Query q = new Query();
QueryBuildDataSource qbds;
QueryRun qr;
QueryBuildRange qbr;
CustTable custTable;
qbds = q.addDataSource(tablenum(CustTable));
qbr = SysQuery::findOrCreateRange(qbds, fieldnum(CustTable, AccountNum));
qbr.value(strfmt('((%1 == %2) || (%3 == %4))',
fieldStr(CustTable, AccountNum),"000015",
fieldStr(CustTable, InvoiceAccount),"000023"));
qr = new QueryRun(q);
if (qr.prompt())
while (qr.next())
custTable = qr.get(tablenum(CustTable));
info(strfmt("AccountNum: %1; InvoiceAccount: %2", custTable.AccountNum, custTable.InvoiceAccount));
ax-erp: X++ Code to get the Ranges / Criteria from Query Blog bot DAX Blogs 0 12.06.2012 12:11
daxline: How to add empty ranges in query Blog bot DAX Blogs 0 28.06.2011 19:11
daxline: SysQuery::findOrCreateRange() - A better way to create dynamic query ranges Blog bot DAX Blogs 0 28.01.2011 23:14
jinx: Dynamics AX – Query-Ranges und Filtereinstellungen des Benutzers Blog bot DAX auf Deutsch 0 04.02.2010 00:05
paruvella: Dynamics Ax - Simple SSRS report example by using Ax-Query and Ranges Blog bot DAX Blogs 0 08.01.2010 16:05
Часовой пояс GMT +3, время: 19:55.
