Старый 14.02.2006, 13:39   #3
SimPai is offline
SimPai
105 / 10 (1) +
Сообщение от RVS
Вот такое забавное сообщение появляется в Event Log-e после запуска Axapta Server Manager:
Object Server Axapta_Work: Client (ip=...) didn't complete connect in a timely manner. This can be caused by client problems, network problems or by non-Axapta clients connecting (intrusion or mistake).
EventId: 171 (EVMSG_NO_CONNECT)
Description: Reports problem connecting a client due to missing response from client. This can be caused by network problems, interrupted startup of client or wrong type of client software. This event will occur when non-Axapta client tries to connect to the Object Server connect point. This will be the case for port-pollers and other software used to interrogate networks which could be signs of hostile attacks on the system.
Action: Evaluate the address of the offending client to validate action and trouble shoot connect problems if it is an Axapta client unable to connect correctly.
Additional information: Client X didn't complete connect in a timely manner. This can be caused by client problems, network problems or by non-Axapta clients connecting (intrusion or mistake).
Applies to: AOS
Удачи.
Последний раз редактировалось SimPai; 14.02.2006 в 13:42.
daxis: Troubleshooting blocked SPIDS in AOS Blog bot DAX Blogs 0 01.04.2009 18:05
Arijit Basu: Multiple AOS in a Multi CPU Machine :) Blog bot DAX Blogs 1 19.12.2007 17:11
Arijit Basu: AX 4 AOS Basics: [Level 100] Blog bot DAX Blogs 0 18.11.2007 14:30
DynamicsTech: What's New in Dynamics Ax 4.0 AOS? Blog bot DAX Blogs 0 12.04.2007 11:50
axaptapedia: Control AOS from command line Blog bot DAX Blogs 0 09.03.2007 14:50
Часовой пояс GMT +3, время: 13:43.
