#20 |
X++: public void Execute(IPluginExecutionContext context) { if (context.Depth > 1) return; Microsoft.Crm.Sdk.Moniker entity = null; if (context.InputParameters.Properties.Contains("Target") && context.InputParameters.Properties["Target"] is Microsoft.Crm.Sdk.Moniker) { entity = (Microsoft.Crm.Sdk.Moniker)context.InputParameters.Properties["Target"]; if (entity.Name != Microsoft.Crm.SdkTypeProxy.EntityName.account.ToString()) { return; } } else { return; } ICrmService serv = context.CreateCrmService(true); TargetRetrieveDynamic targetRetrieve = new TargetRetrieveDynamic(); // Set the properties of the target. targetRetrieve.EntityName = entity.Name; targetRetrieve.EntityId = entity.Id; // Create the request object. RetrieveRequest retrieve = new RetrieveRequest(); // Set the properties of the request object. ColumnSet cols = new ColumnSet(); cols.Attributes.Add("customertypecode"); cols.Attributes.Add("name"); retrieve.Target = targetRetrieve; retrieve.ColumnSet = cols; // Indicate that the BusinessEntity should be retrieved as a DynamicEntity. retrieve.ReturnDynamicEntities = true; // Execute the request RetrieveResponse retrieved = (RetrieveResponse)serv.Execute(retrieve); DynamicEntity retrievedentity = (DynamicEntity)retrieved.BusinessEntity; if (retrievedentity.Properties["customertypecode"] != null) { if (((Picklist)retrievedentity.Properties["customertypecode"]).name == "Клиент") { // Create a QueryExpression. QueryExpression qe = new QueryExpression(); qe.EntityName = "role"; qe.ColumnSet = new AllColumns(); // Set up the join between the role entity // and the intersect table systemuserroles. LinkEntity le = new LinkEntity(); le.LinkFromEntityName = "role"; le.LinkFromAttributeName = "roleid"; le.LinkToEntityName = "systemuserroles"; le.LinkToAttributeName = "roleid"; // Set up the join between the intersect table // systemuserroles and the systemuser entity. LinkEntity le2 = new LinkEntity(); le2.LinkFromEntityName = "systemuserroles"; le2.LinkFromAttributeName = "systemuserid"; le2.LinkToEntityName = "systemuser"; le2.LinkToAttributeName = "systemuserid"; // The condition is to find the user ID. //Microsoft.Crm.Sdk.Query.c ConditionExpression ce = new ConditionExpression(); ce.AttributeName = "systemuserid"; ce.Operator = ConditionOperator.Equal; ce.Values = new object[] { context.UserId }; FilterExpression fe = new FilterExpression(); fe.AddCondition(ce); le2.LinkCriteria = fe; le.LinkEntities.Add(le2); qe.LinkEntities.Add(le); // Execute the query. BusinessEntityCollection bec = serv.RetrieveMultiple(qe); string rolename = "Системный администратор"; bool roleFound = false; if (bec.BusinessEntities.Count > 0) { for (int i = 0; i < bec.BusinessEntities.Count; i++) { if (rolename == ((role)bec.BusinessEntities[i]).name) roleFound = true; } } if (!roleFound) { throw new InvalidPluginExecutionException("У вас нет достаточных прав на просмотр данных о клиенте."); } } } } |
