Старый 29.09.2017, 13:12   #1
alirazazaidi: float value conversion in string SSRS expression and decimal points SSRS dynamics ax 2012 R3.
Источник: https://www.tech.alirazazaidi.com/fl...cs-ax-2012-r3/
Today I have to record very small tip. During development of on SSRS report for Dynamics Ax 2012 R3, End user wants a row at the report footer for  analysis. he wants some kind of percentage  calculation with ‘%’.  A For this I have to use CStr ssrs expression function  like
Ctr(((sum(DataSet!field.Value) / sum(DataSet!field.Value)))*100)+”%”.
Now it is string and shows number of decimal as it result from division. For example  5.4356333. But end user wants formatting like 5.43 .
It is string or text value and SSRS textbox formatting is not apply on it.
Following SSRS expression works for me.
Left(CStr(5.4356333),instr(CStr(5.4356333),”.”)+2)
My Updated expression is something like this
Left(CStr(IIF(Parameters!ProductionReportBM2DS_ItemName.Value = “ITEM-00000420”,((sum(Fields!Scrap.Value)/sum(Fields!TotalConsumption.Value))*100),((sum(Fields!CutLength.Value)/sum(Fields!TotalConsumption.Value))*100))),instr(CStr(IIF(Parameters!ProductionReportBM2DS_ItemName.Value = “ITEM-00000420″,((sum(Fields!Scrap.Value)/sum(Fields!TotalConsumption.Value))*100),((sum(Fields!CutLength.Value)/sum(Fields!TotalConsumption.Value))*100))),”.”)+2) +”%”
conversion from string to type 'decimal' is not valid in reporting services Ion Dynamics CRM: Разработка 6 15.10.2013 13:33
Часовой пояс GMT +3, время: 23:01.
