Старый 08.07.2008, 11:13   #11
Captain is offline
Captain
300 / 81 (3) ++++
Для 5.0 в Cfront добавлены новые функции:
http://blogs.msdn.com/nav_developer/archiv...ng-c-front.aspx
Переменные:
CF - OCX- Cfront
vFile -Variant
vFilter Variant
[codebox]----RUN------
vFile:='C:\ExportFob.fob';
vFilter:='WHERE(Type=CONST(Table),ID=FILTER(1..10))';
CF.ExportFob(vFile,vFilter);[/codebox]
Проблема, как в NAV преобразовать параметры в строковые типы Variant'ов VT_LPWSTR?
You can only export objects as binary .fob files. It is not possible to export objects as text.
In SP1 for NAV version 5, C/Front will no longer check for license permissions when importing files. So the import-functionality works just like importing objects manually, which means that the license file is not checked. In previous versions it was not possible to import new objects or tables with new fields unless the NAV license would allow the user to create those objects or fields manually.
"Собрать стадо из баранов легко, трудно собрать стадо из кошек" Профессор Сергей Капица
Часовой пояс GMT +3, время: 07:34.
