Старый 04.05.2019, 04:20   #1
D365 bug: The transactions on voucher do not balance. Process source document lines in parallel
Источник: http://alexvoy.blogspot.com/2019/05/...er-do-not.html
The transactions on voucher do not balance as per 5/3/2019. (accounting currency: -13.34 - reporting currency: -13.34)
Does it look familiar? Yes, it still happens in D365, while you try to post a partial invoice matching one of product receipts.
A simple scenario. We confirmed a purchase order with one line of quantity 3 and price $10. Receive 1 and then 2. Then try to invoice the first line only.
If you get this error, it is probably because of the general ledger parameter.
Switch it off and try again.
Technical details. Unfortunately I did not manage to find an exact reason, but what I can see is that there are two different ways of creation accounting distribution.
SourceDocumentProcessor.submitSourceDocumentLinesForHeader
When it comes to the parallel creation via TransitionRequest, D365 generates some unbalanced debit and credit records (on the left), but it does not happen when you post a full invoice against both receipts at once (on the right).
There is another article about this parameter, which can be of your interest, too.
The call stack for the aforementioned method call.
> Dynamics.AX.SourceDocumentation.1.netmodule!Dynamics.AX.Application.SourceDocumentStateInProcess.transitionSourceDocumentLines() Line 592 X++
Dynamics.AX.SourceDocumentation.1.netmodule!Dynamics.AX.Application.SourceDocumentStateInProcess.`doTransition() Line 132 X++
Dynamics.AX.SourceDocumentation.1.netmodule!Dynamics.AX.Application.SourceDocumentStateBase.`transition() Line 196 X++
Dynamics.AX.SourceDocumentation.1.netmodule!Dynamics.AX.Application.SourceDocumentStateBase.`performTransitionOrMaintenance() Line 133 X++
Dynamics.AX.SourceDocumentation.1.netmodule!Dynamics.AX.Application.SourceDocumentStateBase.transitionTo() Line 290 X++
Dynamics.AX.SourceDocumentation.1.netmodule!Dynamics.AX.Application.SourceDocumentProcessorBase.`submit() Line 133 X++
Dynamics.AX.SourceDocumentation.1.netmodule!Dynamics.AX.Application.SourceDocumentProcessor.`submit() Line 231 X++
Dynamics.AX.SourceDocumentation.1.netmodule!Dynamics.AX.Application.SourceDocumentProcessor.`submitSourceDocumentImplementation(Dynamics.AX.Application.SourceDocumentHeaderImplementation _sourceDocumentImplementation, bool _updateImplementation, Dynamics.AX.Application.SourceDocumentAccountingStatus _targetSourceDocumentAccountingStatus, Dynamics.AX.Application.SourceDocumentProcessorCaller _caller, Dynamics.AX.Application.SourceDocumentLineItemList _sourceDocumentLineItemList, string _user, bool _doTransitionToCompletedStateAccountFullyQualifiedValidation, bool _doAsynchronousLineProcessing, bool @_updateImplementation_IsDefaultSet, bool @_targetSourceDocumentAccountingStatus_IsDefaultSet, bool @_caller_IsDefaultSet, bool @_sourceDocumentLineItemList_IsDefaultSet, bool @_user_IsDefaultSet, bool @_doTransitionToCompletedStateAccountFullyQualifiedValidation_IsDefaultSet, bool @_doAsynchronousLineProcessing_IsDefaultSet) Line 378 X++
Dynamics.AX.SourceDocumentation.1.netmodule!Dynamics.AX.Application.SourceDocumentProcessorFacade.`submitSourceDocumentImplementation(Dynamics.AX.Application.SourceDocumentHeaderImplementation _sourceDocumentImplementation, bool _updateImplementation, Dynamics.AX.Application.SourceDocumentAccountingStatus _targetSourceDocumentAccountingStatus, Dynamics.AX.Application.SourceDocumentProcessorCaller _caller, string _user, bool _doTransitionToCompletedStateAccountFullyQualifiedValidation, Dynamics.AX.Application.SourceDocumentLineImplementationList _sourceDocumentLineImplementationList, bool _doAsynchronousLineProcessing, bool @_updateImplementation_IsDefaultSet, bool @_targetSourceDocumentAccountingStatus_IsDefaultSet, bool @_caller_IsDefaultSet, bool @_user_IsDefaultSet, bool @_doTransitionToCompletedStateAccountFullyQualifiedValidation_IsDefaultSet, bool @_sourceDocumentLineImplementationList_IsDefaultSet, bool @_doAsynchronousLineProcessing_IsDefaultSet) Line 245 X++
Dynamics.AX.ApplicationSuite.83.netmodule!Dynamics.AX.Application.PurchInvoiceJournalPost.`endLedgerVoucher() Line 1333 X++
Dynamics.AX.ApplicationSuite.36.netmodule!Dynamics.AX.Application.FormletterJournalPost.post() Line 1622 X++
Dynamics.AX.ApplicationSuite.36.netmodule!Dynamics.AX.Application.FormletterJournalPost.`run() Line 2277 X++
Dynamics.AX.ApplicationSuite.37.netmodule!Dynamics.AX.Application.FormletterService.`postJournal(Microsoft.Dynamics.Ax.Xpp.Common _parmTable) Line 714 X++
Dynamics.AX.ApplicationSuite.37.netmodule!Dynamics.AX.Application.FormletterService.`createAndPostJournal() Line 1708 X++
Dynamics.AX.ApplicationSuite.37.netmodule!Dynamics.AX.Application.FormletterService.`processJournal(Dynamics.AX.Application.Printout _printout) Line 1684 X++
Dynamics.AX.ApplicationSuite.37.netmodule!Dynamics.AX.Application.FormletterService.`processFormLetterParmTable(Dynamics.AX.Application.Printout _printout) Line 1476 X++
Dynamics.AX.ApplicationSuite.37.netmodule!Dynamics.AX.Application.FormletterService.`runSingleThread(Dynamics.AX.Application.Printout _printout) Line 1508 X++
Dynamics.AX.ApplicationSuite.37.netmodule!Dynamics.AX.Application.FormletterService.`run() Line 1634 X++
Dynamics.AX.ApplicationSuite.37.netmodule!Dynamics.AX.Application.FormletterService.`postPurchaseOrderInvoice(Dynamics.AX.Application.PurchFormLetterInvoiceContract _contract) Line 836 X++
[External Code]
Dynamics.AX.ApplicationFoundation.9.netmodule!Dynamics.AX.Application.SysOperationServiceController.runOperationInstance(Dynamics.AX.Application.SysOperationServiceController controller) Line 780 X++
Dynamics.AX.ApplicationFoundation.9.netmodule!Dynamics.AX.Application.SysOperationServiceController.runOperationSynchronously() Line 695 X++
Dynamics.AX.ApplicationFoundation.9.netmodule!Dynamics.AX.Application.SysOperationServiceController.`run() Line 581 X++
Dynamics.AX.ApplicationSuite.37.netmodule!Dynamics.AX.Application.FormLetterServiceController.`run() Line 847 X++
Dynamics.AX.ApplicationSuite.83.netmodule!Dynamics.AX.Application.PurchFormLetter.`run() Line 1526 X++
Dynamics.AX.ApplicationPlatform.4.netmodule!Dynamics.AX.Application.SysOperationSandbox.operationExecutionWrapper(object[] serializedOperation) Line 311 X++
[External Code]
Старый 04.05.2019, 15:56   #2
trud is offline
trud
1,039 / 1635 (57) ++++++++
Записей в блоге: 1
Кстати вот классический пример оверинжиниринга
  • давайте сначала напишем SourceDocumentFramework
  • потом поймем что он тормозит, а что-то оптимизировать просто нереально из-сложности
  • Далее кто-то гениальный предлагает - а зачем вообще оптимизировать, давайте просто уберем это из разноски
  • Все радуются идеи, добавляют параметр асинхронной разноски по умолчанию
  • Куча решений ожидает что проводки ГК будут после разноски накладной, и падают при асинхронной разноске
  • Сами же разработчики MS тоже ожидают проводки ГК в момент разноски, из-за этого появляются проблемы с целостностью данных - например эти два фикса для V10
    KB 4499442 Ledger voucher data missing compared to the subledger
    KB 4492844 Transfer to GL when using Transfer mode as Asynchronous and Scheduled Batch does not transfer subledger journal entries consistently.
  • Сейчас наверное кто-то предложит отключать асинхронную разноску по умолчанию
Старый 04.05.2019, 19:22   #3
fed is offline
fed
Аватар для fed
2,916 / 5741 (197) ++++++++++
Как я понимаю, там проблема не асинхронностью разноски (которая была даже в DAX2012 в каком-то виде), а в том что тормозит оно даже с асинхронностью настолько, что они там попытались сделать ассинхронную параллельную разноску. При этом, судя по сообщениям в яммере, время от времени потоки (threads) входили в бесконечный клинч из за блокировок БД. (И судя по оригинальному сообщению топикстартера - еще и ломало механизм балансировки ваучера). Поэтому где-то в свежих версиях, микрософт эту фичу отключил и галочку скрыл. Обещают постепенно этот механизм включать "для избранных клиентов" и потихоньку его доводить.
Вообще, последние анонсы Микрософт, при переводе на русский язык можно свести всего к двум фразам:
  1. А сейчас, со всей этой фигней на борту, мы попытаемся взлететь
  2. А ручки-то, они вон где...
Старый 06.05.2019, 16:44   #4
wojzeh is offline
wojzeh
Аватар для wojzeh
681 / 517 (19) +++++++
так у нас и стоит последняя версия, и таки да, судя по пьесе, надо эту галку по умолчанию отрубать к херам собачьим.
я убил день времени, но так и не смог понять, откуда там вылезают эти 13 с довеском дисбаланса. особый кайф, когда дебуггер прыгает между параллельным исполнением этой красоты.
Felix nihil admirari
За это сообщение автора поблагодарили: gl00mie (10).
dynamicsaxse: November 2018 Release – Dynamics AX2012 R3 update Blog bot DAX Blogs 0 15.11.2018 09:11
emeadaxsupport: The error message "The transactions on voucher XXX do not balance as per [date]. (accounting currency: 50,00 - reporting currency: 50,00)" in open customer transactions settlement Blog bot DAX Blogs 0 13.10.2014 21:11
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
Часовой пояс GMT +3, время: 19:06.
