Старый 18.04.2019, 22:12   #1
D365: Bug in Payment method lookup in Expense report form
Источник: http://alexvoy.blogspot.com/2019/04/...lookup-in.html
You cannot select a payment method in an Expense report line, if you opt for any category containing comma separated value.
There is a bug in standard TrvExpenseLookupHelper class in paymentMethodLookupQuery method: it must use old good queryValue() method.
Otherwise you will get a few values instead of one in the range. Compare them before and after the fix.
[ExtensionOf(classStr(TrvExpenseLookupHelper))]
final static class avrTrvExpenseLookupHelper_Extension
/// A fix for the standard method which does not treat comma separated cost type correctly
public static Query paymentMethodLookupQuery(TrvCostTypeEDT _costType, boolean _excludeImportOnly)
Query query = next paymentMethodLookupQuery(_costType, _excludeImportOnly);
QueryBuildDataSource qbPayMethod, qbValidatePayment;
TrvCostType trvCostType;
trvCostType = TrvCostType::find(_costType);
query = new Query();
qbPayMethod = query.addDataSource(tableNum(TrvPayMethod));
if (trvCostType)
query.queryType(QueryType::Join);
qbValidatePayment = qbPayMethod.addDataSource(tableNum(TrvValidatePayment));
qbValidatePayment.addLink(fieldNum(TrvPayMethod,PayMethod),fieldNum(TrvValidatePayment,PayMethod));
qbValidatePayment.joinMode(JoinMode::ExistsJoin);
//it should be converted by standard queryValue()
qbValidatePayment.addRange(fieldNum(TrvValidatePayment, CostType)).value(queryValue(trvCostType.CostType));
if (_excludeImportOnly)
QueryBuildRange qbr = qbPayMethod.addRange(fieldNum(TrvPayMethod, AutomaticPayment));
qbr.value(queryValue(NoYes::No));
qbr.Status(RangeStatus::Hidden);
return query;
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
dynamicsaxtraining: Paying a Vendor Blog bot DAX Blogs 0 22.03.2012 22:11
Часовой пояс GMT +3, время: 08:32.
