Старый 26.03.2016, 04:15   #1
organicax: Purchase order workflow configuration with auto approval
Источник: http://organicax.com/2016/03/25/purc...auto-approval/
You might want to use workflow to control purchase orders for a specific amount. If you have workflow turned on for all orders then it might get a little tedious for the organization. So in this example let’s have a look at setting up a purchase order workflow that will auto approve if the order is below $5000 else it will go to someone for approval.
Here is a quick look.
AX2012 R3 CU9
Whiled I used CU9 in this example this process is the same in any AX2012 release.
Cheers
Lachlan
Filed under: Procurement and sourcing
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
dynamicsaxtraining: Create purchase order Blog bot DAX Blogs 0 14.12.2009 14:05
Часовой пояс GMT +3, время: 00:31.
