Старый 31.10.2008, 10:05   #1
palleagermark: Setting up E-mail parameters on the AX 2009 VPC July 2008 image
Источник: http://palleagermark.blogspot.com/20...n-ax-2009.html
In order to send e-mail within this image, you need to setup SMTP parameters in AX:
Go to Administration / Setup / E-mail parameters:
Default in the form you'll find the follwing settings:
SMTP port number: 25
Attachment size limit (MB): 10
Enter the following new values:
Outgoing mail server: contoso.com
Local computer name: dynamicsvm
And here is a small job to see if mail can be send:
static void testMail(Args args)
SysMailer   sysMailer = new SysMailer();
sysMailer.quickSend("administrator@contoso.com", "administrator@contoso.com", "Suject", "Body");
Please note that the test mail might end up in your Outlook junk-mail folder.
AX UK: Microsoft Dynamics AX 2009 Exam Deadline extended to 1st July 2009 Blog bot DAX Blogs 0 03.12.2008 19:05
jinx: Microsoft Dynamics AX 2009, Windows Server 2008 und SQL Server 2008 Blog bot DAX auf Deutsch 0 12.10.2008 20:10
Часовой пояс GMT +3, время: 11:05.
