Вернуться   AXForum > Microsoft Dynamics AX (Axapta) > DAX: За рубежом > DAX in English
Зарегистрироваться Правила Справка Пользователи Блоги Сообщения за день Поиск Все разделы прочитаны Проекты Забыли пароль?
Старый 23.09.2008, 12:38  Ссылка на сообщение   #1
axstart is offline
axstart
MVP
NavAx Club
13 / 10 (1) +
error at call static method for CLRobject
Hi folks,
i have created a .net dll for ax, it is part of my global asambly cach, it compiles (great :-))
but at run time i get this error occur
client static boolean updateCRMfromCustTable(custTable _newCustTable, custTable _orgCustTable)
CrmAx.CustContainer custContainer;
CrmAx.AdresContainer adresContainer;
System.String connectionURl;
System.Collections.ArrayList errorList;
InteropPermission interopPermission;
str errorStr;
str address;
int errorCount;
int errorMax;
//Run on server
InteropPermission = new interoppermission(Interopkind::ClrInterop);
interoppermission.assert();
connectionURl = "http://hbd52/mscrmservices/2007/crmservice.asmx";
try
custContainer = CrmAx.CustContainer::GetCustContainer(_newCustTable.CRMAccountID,connectionURl); ERROR OCCUR
custContainer.set_AccountNum
MVP
Старый 23.09.2008, 14:22  Ссылка на сообщение   #3
axstart is offline
axstart
MVP
NavAx Club
13 / 10 (1) +
the error is clrobject static method invocation error
MVP
Старый 24.09.2008, 19:27  Ссылка на сообщение   #4
axstart is offline
axstart
MVP
NavAx Club
13 / 10 (1) +
i have anupdate.
the paramter system.Guid does not always work correctly even when the system.Guid is generated in AX. It looks like some issue with a general MS library. Some MS services work fine, other have this issue. Have somenone seen somthing before?
MVP
Старый 25.09.2008, 23:23  Ссылка на сообщение   #5
Ievgenii is offline
Ievgenii
Аватар для Ievgenii
54 / 38 (2) +++
Hi Dick,
Can you please repost the question to Dynamics AX Technical Discussion Forum, so we can loop in DAX Server team to find out the root of the issue :0)
Thx,
Ievgenii Korovin| Dynamics Ax SCM| Microsoft Corp| http://blogs.msdn.com/DynamicsAxSCM/
Реклама
Тема Автор Раздел Ответов Последнее сообщение
DeniZone: Invoking a method on a field in a form's datasource Blog bot DAX Blogs 0 13.02.2009 14:05
ClrObject static method invocation error. offenmeier DAX: Программирование 4 08.10.2008 09:05
Как понять что вызывает исключение Invalid Method Call Jab Straight DAX: Программирование 0 17.12.2007 23:23
axaptapedia: Display method Blog bot DAX Blogs 0 29.08.2007 16:30
Рейтинг@Mail.ru Rambler's Top100
Часовой пояс GMT +4, время: 14:50.
