Старый 02.04.2007, 16:50   #1
casperkamal: Adding a Table field through X++ code in Dynamics Ax
Источник: http://casperkamal.spaces.live.com/B...CD63!258.entry
   Sometime back there was a query in one of the discussion forum about inserting a table field through code. I did a small job to demonstrate that, just  thought would write that down in my blog too...... and here it is.
I have added sufficient comments to make it explanatory.
 static void JobCreateTableFields(Args _args)
    #AOT
    #TreeNodeSysNodeType
    //find the Table
TreeNode                   tablenode = TreeNode::findNode(#TablesPath).AOTfindChild('LedgerTable');
    TreeNode                   fieldNode, tn;
    Struct                         properties;
    Struct                         propertyInfo;
    Array                          propertyArray;
    str                               propertyValue;
AOTTableFieldList    lst;
    str                               name;
    Counter                     propertyCount;
    int                               i;
    Map                            map = new Map(Types::String, Types::String);
    //Find the tables field node
lst = tablenode.AOTfindChild('fields');
    //add the field
    lst.addString('Test');
    //now find the node in the tree
    fieldNode  =  lst.AOTfindChild('Test');
    //get the properties structure
    properties = fieldNode.AOTgetPropertiesExt();
    //Update the properties map with the required properties
    map.insert('ExtendedDataType', 'LedgerAccount');
    // get the number of properties
    // and the array containing the properties structure
    propertyCount = properties.value('Entries');
    propertyArray = properties.value('PropertyInfo');
    for (i = 1; i < propertyCount; i ++)
        propertyInfo  = propertyArray.value(i);
        name = propertyInfo.value('Name');
//see if we have inserted the property name in to the map
if (map.exists(name))
//set the property
  propertyInfo.value('Value', map.lookup(name));
    //set the properties structure
    fieldNode.AOTsetPropertiesExt(properties);
    //save the treenode
    tablenode.AOTsave();
//Let us open the table
    //and see if the code works :)
    tablenode.AOTnewWindow();
click to download it from Axaptapedia
За это сообщение автора поблагодарили: alex55 (1).
Старый 02.04.2007, 17:05   #2
Сообщение от Blog bot Посмотреть сообщение
В этот момент поле запишется в тот слой, в котором в данный момент работает пользователь.
Если разработчик работает в слое cus, а пользователь в слое usr
И если код выполнит пользователь, то поле попадет в слой usr.
В результате разработчик не сможет удалить это поле пока не перейдет в слой usr.
А самое поганое, если помимо AOT'а информация о сохраняется где-то в базе.
Разработчик из базы удалить может, а из AOT'а нет, пока не перейдет в другой слой.
Были жуткие проблемы в российском модуле Расчеты с персоналом.
В этом модуле создание записи в таблице Группы времен приводит к автоматическому созданию поля в табелях.
Посмотрите какие проверки пришлось делать в этом модуле, чтобы не изменять идеологию... Не программируйте так.
casperkamal: Using record templates in code for Dynamics Ax 4.0. Blog bot DAX Blogs 0 10.05.2008 19:14
Inside Dynamics AX 4.0: Inside the Business Connector Blog bot DAX Blogs 0 04.10.2007 05:15
casperkamal: A small addition to creation of Table throug x++ code in Dynamics Ax Blog bot DAX Blogs 0 03.04.2007 23:11
Часовой пояс GMT +3, время: 10:55.
