1. It is enough to delete the class, save and close the report. Then add the DP class again. The report will work. 2. Remove the class, then clear all field references to fields, save and close the report. Then add the DP class and manually re-reference the fields. The DP class must be removed from the report. It won't work without it. But I usually had enough of option 1
Возможно сделать все. Вопрос времени Последний раз редактировалось sukhanchik; 08.10.2021 в 22:54. |
| Теги |
| axapta 2012, field metadata, report deploy exception, ssrs |
