Старый 07.10.2021, 17:08   #2
sukhanchik is offline
sukhanchik
Аватар для sukhanchik
3,343 / 3563 (125) ++++++++++
AX 2012?
For AX 2012:
Let's try the standard actions first.
1. Let's compile all our objects without errors and build a complete CIL (Close Visual Studio)
2. Restart AOS
3. Launch Visual Studio
4. Remove the DP-class from the SSRS-report along with the fields and parameters that were registered there
5. Let's save the SSRS-report and the project in AOT and make sure that the compilation of the report and the project occurs without errors.
6. Let's re-add the DP-class to the report as a data source
7. Let's rewrite the fields in the controls.
8. We'll compile everything and rebuild the full CIL
9. After any assembly of a complete CIL - restart the AOS.
Errors should go away
axapta 2012, field metadata, report deploy exception, ssrs
dynamicsaxse: November 2018 Release – Dynamics AX2012 R3 update Blog bot DAX Blogs 0 15.11.2018 09:11
bojensen: Dynamics AX 2012 error when running SSRS-reports just after deleting a table field from report’s temporary table – Addicted2AX / Addicted2SQL Blog bot DAX Blogs 0 09.01.2013 17:11
emeadaxsupport: Error viewing an SSRS Report from Microsoft Dynamics AX 2009 - Sys.WebForms.PageRequestManagerServerErrorException: An unknown error occured while processing the request on the server Blog bot DAX Blogs 0 22.03.2012 02:13
Часовой пояс GMT +3, время: 17:53.
