I see in your code if startDateTime contains current 2019 year then endDateTime should contain the date of 2018 year:
Here you substract the value of 1 year from startDateTime and assign result to endDateTime. Such conditions do not allow you to get something else than nothing.
No, it doesn't look correct. Due to your current conditions in a case when docuRef.TypeId != #SPP you should pull the records for any company (RefCompanyId) and any table (RefTableId). I'm sure you pulled the records with empty TypeId field right for this case. Enclose following code in additional braces and you will see the difference.
X++: while select createdBy, createdDateTime, TypeId from docuRef where docuRef.RefTableId == tableNum(CustTable) && ((docuRef.createdDateTime >= endDateTime && docuRef.createdDateTime <= startDateTime && docuRef.TypeId == #SPP) || docuRef.TypeId != #SPP) join AccountNum, Party from custTable where custTable.RecId == docuRef.RefRecId && custTable.dataAreaId == docuRef.RefCompanyId && custTable.Blocked == CustVendorBlocked::No exists join partyLocation where partyLocation.IsPrimary == true && partyLocation.Party == custTable.Party exists join postalAddress where postalAddress.Location == partyLocation.Location exists join addressCountryRegion where addressCountryRegion.CountryRegionId == postalAddress.CountryRegionId && addressCountryRegion.SanctionedCountry_mb == NoYes::Yes { tmpCustVendListTable.clear(); if (custVendAcc != custTable.AccountNum) { custVendAcc = custTable.AccountNum; } else { if (docuRef.TypeId != #SPP) continue; } tmpCustVendListTable.BPAccountNum = custVendAcc; tmpCustVendListTable.BPName = custTable.name(); if (docuRef.TypeId == #SPP) { tmpCustVendListTable.ResponsibleUser = XUserInfo::find(false, docuRef.createdBy).name; tmpCustVendListTable.ScreeningDateTime = docuRef.createdDateTime; } tmpCustVendListTable.insert(); } Thank you dech. |
| Теги |
| axapta 2012, docuref, missing value, ssrs, typeid |
