Старый 02.12.2011, 00:13   #1
emeadaxsupport: Opening a Report on AX 2012 raises infolog error: The default Report Server Configuration ID could not be found in the SRSServers table.
Источник: http://blogs.msdn.com/b/emeadaxsuppo...ers-table.aspx
Consider the following scenario:
- You have one Microsoft Dynamics AX 2012 AOS instance fully configured, and users are able to open reports from the AX client connecting to this instance.
- You now add an additional AOS instance.
- Users connecting to the additional/new AOS instance get the following infolog error when trying to open an SSRS report:
The error occurs because you need to add the new AOS server instance to the Report Servers form. Follow through the steps given at http://technet.microsoft.com/en-us/l...hh389773.aspx, and ensure under the Application Object Server information tab, you select the new AOS instance.
--author:Anup Shah--editor:Anup Shah--date:01/Dec/2011
emeadaxsupport: Error message “The value ‘xxx’ is not found in the map” when opening Workflow configuration Blog bot DAX Blogs 0 10.02.2010 00:07
emeadaxsupport: Error when deploying AX Report to SQL Reporting Server - Client found response type of 'text/html;charset=utf8;' but expected 'text/html' Blog bot DAX Blogs 0 12.01.2010 04:44
Часовой пояс GMT +3, время: 11:11.
