#11 |
Как-то так:
X++: custVendTrans.ReasonRefRecId = reasonRefRecID; // If the amount, which is the total invoice amount, is zero, then the amountMST and amountCur also must be zero if (amountCur) { if (_useSubLedger) { // <GIN> if (TaxWithholdParameters_IN::checkTaxParameters()) { amountCur += taxWithholdAmount; } // </GIN> custVendTrans.AmountMST = CurrencyExchangeHelper::mstAmount(amountCur, currencyCode, transDate, Currency::noYes2UnknownNoYes(triangulation), exchRate, exchRateSecondary); } else { // <GEERU> if (ledgerBalances) { custVendTrans.AmountMST = CurrencyExchangeHelper::amount(postedAmountMST, Ledger::accountingCurrency()); } else { // </GEERU> custVendTrans.AmountMST = CurrencyExchangeHelper::amount(ledgerPostingReference.lastAmountMST(), Ledger::accountingCurrency()); // <GEERU> } // </GEERU> } } else { custVendTrans.AmountMST = 0; } X++: /// <summary> /// Calculates the total of the multiple posted balance amount based on /// the specific currency code and the object of <c>CurrencyExchangeHelper</c>. /// </summary> /// <param name = "_curencyCode">The transaction currency originating the conversion.</param> /// <param name = "_currencyExchangeHelper">The <c>CurrencyExchangeHelper</c> class which manages calculations between currencies.</param> /// <returns>A container of AmountCur and AmountMst.</returns> private container calculatePostedMultipleBalanceAmounts_RU(CurrencyCode _curencyCode, CurrencyExchangeHelper _currencyExchangeHelper) { int i; boolean correction; AmountCur balanceValue; AmountCur retAmountCur; amountMST retAmountMst; for (i = 1; i<=conLen(ledgerBalances); i++) { [correction, balanceValue] = conPeek(ledgerBalances, i); retAmountCur += balanceValue; retAmountMST += _currencyExchangeHelper.calculateTransactionToAccounting( _curencyCode, balanceValue, true ); } return [retAmountCur, retAmountMst]; } X++: if (countryRegion_RU) { custVoucher.parmSalesInvoicePostingType_RU(custInvoiceJour_RU.InvoicePostingType_RU); if (this.postBalanceAsManyLedgerTransactions_RU()) { custVoucher.parmLedgerBalances_RU([[false, salesTotals.totalAmountBySign_RU(false)], [this.parmStorno(), salesTotals.totalAmountBySign_RU(true)]]); } } |
