Старый 28.11.2017, 05:32   #21
trud is offline
trud
1,039 / 1635 (57) ++++++++
Записей в блоге: 1
Сообщение от twilight Посмотреть сообщение
И какая практическая польза от этого теста? )
Кстати я понял , неплохая статья по тестированию SQL Azure и сравнению его со скоростью SQL на ноутбуке
http://cdn2.hubspot.net/hubfs/233452...1-2017-ENG.pdf
т.е. у них получился просто огромный разброс в скорости (500%) в зав-ти от датацентра, по видимому чтобы это хоть как-то понимать, мс и создала этот тест
The results for both, the physical and virtual machines, shows that the execution time is significantly lower/faster than for the Azure Premium P2 Tier. Only the execution time for Azure Premium P2 database, located in West Europe, is comparable to results from physical and virtual machines, but still 50 % slower than the slowest servers.
For the Azure Basic databases, there was a 20% performance difference between the three tested locations (West Europe, West Japan and West US). For Standard S3 databases the difference had grown to 25%, while on Azure Premium P2 databases the performance difference was a staggering 500%. When the same test takes 5 times as longer on one database than the other, given the same DTU strength, it’s
surprising that it can be sold as the same product. So in other words, ordering the same service at different locations you may end up with completely different underlying hardware.
За это сообщение автора поблагодарили: Logger (3), EVGL (5), fed (5), mazzy (2).
performance, performance test tool
jaestevan: Microsoft Dynamics 365 for Operations Blog bot DAX Blogs 0 02.11.2016 01:11
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 15 Blog bot Dynamics CRM: Blogs 1 10.02.2016 10:26
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 17 Blog bot Dynamics CRM: Blogs 0 10.05.2014 06:30
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 16 Blog bot Dynamics CRM: Blogs 0 23.01.2014 03:15
Часовой пояс GMT +3, время: 11:06.
