Старый 08.08.2016, 01:40   #8
Vadik is offline
Vadik
Модератор
Аватар для Vadik
3,631 / 1853 (69) ++++++++
Внезапно подумалось - а "Note: After you download the zip file, right-click it, and then select Properties. Then, in the Properties dialog box, on the General tab, click Unblock to unlock the files. Finally, extract the files, and continue with the next step" - сделано ?
https://ax.help.dynamics.com/en/wiki...ackage-in-ax7/
-ТСЯ или -ТЬСЯ ?
За это сообщение автора поблагодарили: gl00mie (3).
d365o, hotfix
patrickmouwen: AX7 – My top 12 highlights Blog bot DAX Blogs 0 27.02.2016 13:11
mfp: What is new in X++ in AX7? Blog bot DAX Blogs 2 10.02.2016 00:29
Kashperuk Ivan: Tutorial: Update product receipts for loads and how to handle items missing from ASN Blog bot DAX Blogs 0 22.09.2014 18:11
emeadaxsupport: Calling the Update Operation on Services in AX 2012 Blog bot DAX Blogs 0 22.05.2012 02:12
fed: Net requirements update in MRP Module and Working Set of MRP Blog bot DAX Blogs 14 08.05.2012 13:09
Часовой пояс GMT +3, время: 04:11.
