Старый 22.05.2012, 02:12   #1
emeadaxsupport: Calling the Update Operation on Services in AX 2012
Источник: http://blogs.msdn.com/b/axsupport/ar...n-ax-2012.aspx
Calling the update operation on web services can range from simple
to very complicated depending on the entities/tables you are updating. If the entity you are calling is not a date
effective entity, then the service's update method is easy to call.
You can tell if a table is date effective by going in the
AOT to the Data Dictionary > Tables > Find the tables that comprise the
service > Right-click on the table and choose Properties. In the property sheet, look for the
ValidTimeStateFieldType property. If the
property is set to "None" then the table is NOT date effective. You will need to look at every table in the
service to see if that property is set to none.
If the service is not date effective, like the sales order
service, then you can call the service using the find and then the update operations. In the example below, I retrieve a sales
order using the find method and then I update the SalesQty and SalesPrice
fields on each sales line in the retrieved sales order.
static void Main(string[] args)
//First find the order
AxdSalesOrder salesOrder = Program.FindOrder();
//Now update it
Program.UpdateOrder(salesOrder);
static AxdSalesOrder FindOrder()
CallContext context = new CallContext();
context.Company = "ceu";
string salesId = "SO-101244";
AxdSalesOrder foundSalesOrder = null;
//Instantiate an instance of the service client class
SalesOrderServiceClient proxy = new SalesOrderServiceClient();
try
foundSalesOrder = proxy.find(context, Program.createQueryCriteria(salesId));
Console.WriteLine("The sales order was found.");
catch (Exception e)
Console.WriteLine("The sales order was not found.");
return foundSalesOrder;
private static QueryCriteria createQueryCriteria(string salesIdValue)
CriteriaElement[] criteriaElements = new CriteriaElement[1];
criteriaElements[0] = new CriteriaElement();
criteriaElements[0].DataSourceName = "SalesTable";
criteriaElements[0].FieldName = "SalesId";
criteriaElements[0].Value1 = salesIdValue;
QueryCriteria queryCriteria = new QueryCriteria();
queryCriteria.CriteriaElement = criteriaElements;
return queryCriteria;
static void
UpdateOrder(AxdSalesOrder salesOrder)
CallContext();
foreach (AxdEntity_SalesTable
salesTable in salesOrder.SalesTable)
foreach (AxdEntity_SalesLine
salesLine in salesTable.SalesLine)
salesLine.SalesQty =
salesLine.SalesQty + 1;
salesLine.SalesPrice =
salesLine.SalesPrice + 2;
salesLine.SalesPriceSpecified = true;
try
proxy.update(context, Program.createEntityKeyList(),
salesOrder);
Console.WriteLine("The sales order was successfully updated");
catch (Exception
e)
Console.WriteLine("The sales order was not updated.");
Unlike the sales order service, the customer service is date
effective because it contains the DirPersonName, DirOrganizationName,
DirPartyLocation, etc. tables which have their ValidTimeStateFieldType
properties set to something other than None.
Date effective services have properties added at the document level (the
highest level in the service) to indicate how you want to set the date effective
entities. The properties are ValidTimeStateType,
ValidAsOfDateTime, ValidFromDateTime and ValidToDateTime. Either you can set those at the document
level or you can set the date effective fields on each entity in the service
that is date effective. In the example
code below, I call the read method to retrieve a customer and then I create a
new instance of a customer, set the date effective properties on the document according
to what they are on the retrieved customer and then update the CreditMax field
on the customer.
static void
Main(string[] args)
string customer = "1104";
AxdCustomer foundCustomer = null;
CallContext();
CustomerServiceClient proxy = new CustomerServiceClient();
try
foundCustomer = proxy.read(context, Program.readCritera(customer));
Console.WriteLine("Read worked");
Program.updateCustomer(foundCustomer);
catch (Exception
e)
Console.WriteLine(e.Message);
private static
EntityKey[] readCritera(string customerAccount)
AxdEntity_CustTable custTable = new AxdEntity_CustTable();
EntityKey[] entityKeyList = new EntityKey[1];
EntityKey key = new
EntityKey();
KeyField[] keyFields = new
KeyField[1];
KeyField keyField = new
KeyField();
keyField.Field = "AccountNum";
keyField.Value = customerAccount;
keyFields[0] = keyField;
key.KeyData = keyFields;
entityKeyList[0] = key;
return entityKeyList;
private static void
updateCustomer(AxdCustomer customer)
CallContext();
customer.CustTable[0];
AxdCustomer axdCustomer2 = new AxdCustomer();
axdCustomer2.ValidTimeStateType = customer.ValidTimeStateType;
axdCustomer2.ValidTimeStateTypeSpecified = true;
axdCustomer2.ValidAsOfDateTime = customer.ValidAsOfDateTime;
axdCustomer2.ValidFromDateTime =
customer.ValidFromDateTime;
axdCustomer2.ValidToDateTime = customer.ValidToDateTime;
AxdEntity_CustTable custTableNew = new AxdEntity_CustTable();
custTableNew._DocumentHash = custTable._DocumentHash;
custTableNew.RecId = custTable.RecId;
custTableNew.RecVersion = custTable.RecVersion;
custTableNew.action = AxdEnum_AxdEntityAction.update;
custTableNew.actionSpecified = true;
custTableNew.CreditMax = custTable.CreditMax + 10;
custTableNew.CreditMaxSpecified = true;
custTableNew.CustGroup = custTable.CustGroup;
axdCustomer2.CustTable = new AxdEntity_CustTable[1] { custTableNew };
try
proxy.update(context, Program.readCritera("1104"), axdCustomer2);
Console.Write("Worked");
Console.ReadLine();
catch (Exception
e)
Console.WriteLine("Failed");
Console.ReadLine();
As an alternative to setting the properties at the document
level (AxdCustomer) I can set the date effective properties on each table in
the service that is date effective. As
you'll notice the code get clunkier and more difficult to do programmatically. The example code below accomplishes the same
goal of retrieving the customer using the read method and then it updates the
CreditMax for that customer.
args)
CallContext();
try
AxdEntity_DirParty_DirPartyTable
returnedPartyTable = foundCustomer.CustTable[0].DirParty[0];
catch (Exception
e)
private static EntityKey[] readCritera(string
customerAccount)
EntityKey key = new EntityKey();
KeyField[] keyFields = new KeyField[1];
KeyField keyField = new KeyField();
return
entityKeyList;
private static void updateCustomer(AxdCustomer
customer)
foreach (AxdEntity_CustTable
custTable in customer.CustTable)
custTable._DocumentHash = custTable._DocumentHash;
custTable.RecId = custTable.RecId;
custTable.RecVersion = custTable.RecVersion;
custTable.action = AxdEnum_AxdEntityAction.update;
custTable.actionSpecified = true;
custTable.CreditMax =
custTable.CreditMaxSpecified = true;
#region Update the date effective
entities
AxdEntity_DirParty_DirOrganization
dirPartyTable = (AxdEntity_DirParty_DirOrganization)custTable.DirParty[0];
dirPartyTable.action = AxdEnum_AxdEntityAction.update;
dirPartyTable.actionSpecified = true;
AxdEntity_OrganizationName orgName =
dirPartyTable.OrganizationName[0];
orgName.action = AxdEnum_AxdEntityAction.update;
orgName.actionSpecified = true;
orgName.updateMode = AxdEnum_ValidTimeStateUpdate.Correction;
orgName.updateModeSpecified = true;
//Update the postal addresses
AxdEntity_DirPartyPostalAddressView[]
postalAddresses = dirPartyTable.DirPartyPostalAddressView;
foreach (AxdEntity_DirPartyPostalAddressView
postalAddress in postalAddresses)
postalAddress.action =
postalAddress.actionSpecified = true;
postalAddress.updateMode = AxdEnum_ValidTimeStateUpdate.Correction;
postalAddress.updateModeSpecified = true;
postalAddress.RecId =
postalAddress.RecId;
postalAddress.RecVersion
= postalAddress.RecVersion;
postalAddress.Roles = "Home";
//Update the electronic addresses
AxdEntity_DirPartyContactInfoView[]
electronicAddresses = dirPartyTable.DirPartyContactInfoView;
foreach (AxdEntity_DirPartyContactInfoView
electronicAddress in electronicAddresses)
electronicAddress.action = AxdEnum_AxdEntityAction.update;
electronicAddress.actionSpecified = true;
electronicAddress.updateMode = AxdEnum_ValidTimeStateUpdate.Correction;
electronicAddress.updateModeSpecified = true;
electronicAddress.RecId = electronicAddress.RecId;
electronicAddress.RecVersion = electronicAddress.RecVersion;
#endregion
try
proxy.update(context, Program.readCritera("1104"), customer);
Console.ReadLine();
catch (Exception
e)
Console.ReadLine();
emeadaxsupport: Turn off Keep Update objects in AX 2012 for new installations Blog bot DAX Blogs 0 19.04.2012 21:11
Часовой пояс GMT +3, время: 12:54.
