Старый 11.05.2011, 18:53   #4
kashperuk is offline
kashperuk
Аватар для kashperuk
4,361 / 2084 (78) +++++++++
Well, so, first of all, you should change the fields on the query (you need to set the property Dynamic on the Fields node to No, and then manually add only the fields you need).
But also, in the service setup, you can control, which fields are visible/mandatory/etc.
I don't have an AX 2009 version here, but you should be able to find it - it's somewhere under AIF setup.
За это сообщение автора поблагодарили: ideveloper (1).
display field, query, service, aif
gatesasbait: Improved AOT Queries in Ax2009 Blog bot DAX Blogs 3 12.10.2011 15:03
dax-lessons: Easy way to write queries/select statements – Editor scripts Blog bot DAX Blogs 0 17.12.2010 21:11
AX UK: Building a Microsoft Virtualisation & Management Practice Blog bot DAX Blogs 0 17.02.2010 21:07
Code Access Security - ошибка Best Practice Vhaldemar DAX: Программирование 9 05.11.2008 11:48
C# and AX Development: Complex Queries in AX Blog bot DAX Blogs 2 06.03.2008 17:57
Часовой пояс GMT +3, время: 18:42.
