Старый 14.04.2011, 11:41   #34
sukhanchik is offline
sukhanchik
Аватар для sukhanchik
3,342 / 3563 (125) ++++++++++
Но от этого же отказались в 2012 - или я неправильно понял - и текст был не об этом?
Visio Export for reporting relationships, locations, and organizational structure views
In Microsoft Dynamics AX 2009, you can export the reporting relationships view, locations view, and organizational structure view to Visio.
Reason for deprecation: Architectural changes and a new control were added to all three of the views. The new control enables more nodes to be displayed in the hierarchical structure. You can also create and modify nodes directly from the new control. The architectural changes would have required extensive changes to the Visio Export feature.
Replaced by another feature: No. The Visio Export feature is no longer available, and there is no replacement feature.
ax2012
Проблема с поиском в InventTrans после changeCompany (DAX4) Raven Melancholic DAX: Программирование 11 13.03.2008 14:02
Связь таблиц InventTrans и PurchLine Pustik DAX: Программирование 2 25.11.2004 12:23
Часовой пояс GMT +3, время: 14:31.
