Старый 06.02.2011, 19:12   #1
ukax: The Future of the AX Demonstration Environment
Источник: http://blogs.msdn.com/b/ukax/archive...vironment.aspx
Hi All
As the launch of AX 2012 gets closer I thought it worthwhile to flag up the future demonstration environment of this release. It is fair to say that any Demonstration VMs for AX 2012 will only run through the Hyper-V platform. The PTA Team has discussed this point with partners in some depth over the last few years on how our demonstration environments would migrate to this technology. However what has become apparent is that we still have partners running the demonstration toolkits through Virtual PC. This is fine but clearly you won’t be able to take advantage of any of our 64 Bit Technologies such as SharePoint 2010. And with the consideration of AX 2012 I would strongly recommend that it is time to change.
So in short I wanted to bring this to everyone’s attention in plenty of time, prior to launch. There are numerous articles on how you can configure your laptops to dual boot between Server 2008 R2 and Windows 7 or how you can simply run Server 2008 R2 as your preferred operating system. Applying the desktop themes over Server 2008 R2 provides an experience which is almost identical to the UI of Windows 7.
Here’s one article to get you started from our TechNet Wiki, to access the article Click Here. In terms of machine specifications, I’d rather not get into too much detail as this is a debate which has many answers!!! However I personally run a machine with 16 Gbyte RAM, Intel i7 vPro Processor and a secondary hard drive in the media bay to store the VMs. Once it is up and running it quite literally flies.
So I encourage you all, if you have not already done so, to start migrating your Presales and Consultants machines to run the Hyper-V environment.
Regards
Andrew
Старый 07.02.2011, 09:40   #2
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
any Demonstration VMs for AX 2012 will only run through the Hyper-V platform. However what has become apparent is that we still have partners running the demonstration toolkits through Virtual PC. This is fine but clearly you won’t be able to take advantage of any of our 64 Bit Technologies such as SharePoint 2010.
Читай: Virtual PC не умеет запускать x64 гостевые операционки, а Microsoft все свои сервера постепенно переводит исключительно на 64 бита (см. тот же SharePoint Server 2010, Exchange Server 2010, Windows Server 2008 R2, etc).
There are numerous articles on how you can configure your laptops to dual boot between Server 2008 R2 and Windows 7 or how you can simply run Server 2008 R2 as your preferred operating system. So I encourage you all, if you have not already done so, to start migrating your Presales and Consultants machines to run the Hyper-V environment.
Типа ставьте всем консультантам на машины W2K8 R2? Подумаешь, что стандартная редакция стоит вчетверо дороже, чем, скажем, W7 Pro (веб-редакция не подойдет - там нет роли Hyper-V). Теоретически можно попробовать извернуться с бесплатным Hyper-V Server, но тогда собственно демонстрацию надо будет проводит не на своем ноуте, а на дополнительном компе (заказчика?), подключаясь с него к виртуалке через удаленный рабочий стол.
Скромняга!
Старый 08.02.2011, 10:22   #3
Poleax is offline
Poleax
Аватар для Poleax
1,353 / 595 (22) +++++++
Записей в блоге: 34
Да, образы VPC для Hyper-V Server вызывает неудобства.
Нехватка физ. ресурсов заставила по экспериментировать.
Чего только стоит запустить ax2009 demo vpc: полностью настроенная виртуальная машина со средствами разработки.
Пробовал конвертировать файлы (AX5-W8R2-01.vhd, AX5-W8R2-01_DB.vhd) в формат для VirtualBox и VMWare.
C основным диском проблем нет, системы запустились и на VirtualBox и VMWare. Но есть кучу дополнительных дисков, после конвертирования их не удалось нормально подключить к VPC.
На ноутбуке (Intel i720 4Гб) пришлось выкручиваться, используя Установка Windows Server 2008 R2 на один раздел с Windows 7 при помощи Hyper-V
Т.е. при загрузке ноута имею выбор из 2-х ОС, Windows Server 2008 R2 в виде файла VHD (проще его потом удалить или заменить другим VHD).
В Windows Server 2008 R2 включен Hyper-V Server в котором подключены и настроены VPC Microsoft Dynamics AX 2009 - Refresh 4
P.S. осталось память докупить. Жаль у меня максимум только 8Гб ОЗУ.
ax2009, ax2012, vpc, hyper-v
Sample Design Patterns: Future managers and Microsoft Dynamics AX Blog bot DAX Blogs 0 28.12.2010 13:11
Часовой пояс GMT +3, время: 17:30.
