#12 |
Гость
вот лог \Classes\BookDataCalc_Purch_RU\dialog 1 3 delete from GLS \Classes\BookDataCalc_Purch_RU\getFromDialog 1 3 delete from GLS \Classes\BookDataCalc_Purch_RU\pack 1 3 delete from GLS \Classes\BookDataCalc_Purch_RU\unpack 1 3 delete from GLS Error \Classes\CostAllocationPost_RU\newFromCaller 19 32 Operand types are not compatible with the operator. Error \Classes\CostAllocationPostOverhead_RU\adjustInvoice 21 52 The table does not contain this field. Error \Classes\CostAllocationPostOverhead_RU\runPost 8 10 The class CostAllocationPostOverhead_RU does not contain this function. \Classes\CustVendExchAdj\classDeclaration 35 61 SEKL - ANALYZE USAGE OF THIS VARIABLE Error \Classes\RDeferralsProposalWritingOff\createJournalLines 66 101 findFirstType is not a class function. Error \Classes\RPayCreateDeferrals\checkDeferralsProfile 11 26 The table does not contain this field. Error \Classes\RPayCreateDeferrals\initDeferralAmount 3 5 Variable RDeferralsBookAmount has not been declared. Error \Classes\RPayCreateDeferrals\initDeferralModel 3 5 Variable RDeferralsBookAmount has not been declared. Error \Classes\RPayCreateDeferrals\postDeferralsTrans 19 72 The enumeration does not exist. \Classes\RPayPFReportXML_SZV6\DEL_docQty 1 3 delete Warning \Classes\RPayReportRSV1_2010\getEmplQtyAvg 40 61 Assignment/Comparison loses precision. \Data Dictionary\Tables\CustParameters\Methods\numRefCustAdvanceInvoiceId_CZ 1 3 delete from GLS \Data Dictionary\Tables\CzCustAdvanceInvoiceTable\Methods\euroTriangulation 1 3 delete \Data Dictionary\Tables\CzCustAdvanceInvoiceTable\Methods\exchRate 1 3 delete \Data Dictionary\Tables\CzCustAdvanceInvoiceTable\Methods\exchRateSecondary 1 3 delete Error \Data Dictionary\Tables\RPayAverageEarnEmplPeriodTable\Methods\allowReverseDeferral 11 70 The enumeration does not exist. Error \Data Dictionary\Tables\RPayAverageEarnEmplPeriodTable\Methods\reverseDeferrals 7 5 Variable RDeferralsTransactionReversal has not been declared. Error \Data Dictionary\Tables\RPayTrans\Methods\checkDeferrals 14 71 The enumeration does not exist. Error \Data Dictionary\Tables\RPayTrans\Methods\reverseDeferrals 8 5 Variable RDeferralsTransactionReversal has not been declared. \Data Dictionary\Tables\SalesLine\Methods\originalInvoiceId_CZ 1 3 This method is to be removed. \Reports\CzSalesAdvanceInvoice_Table\Methods\classDeclaration 1 3 rename report to CustAdvanceInvoice_Table_CZ \Reports\CzSalesAdvanceInvoice_Table\Methods\classDeclaration 2 3 rename menu item CzSalesAdvanceInvoice_Table Последний раз редактировалось AX2009; 19.12.2010 в 21:32. |
| Теги |
| ax2009, payroll, rollup |
