mscrmblog: Generating/Rendering a PDF from a sql reporting services report - CRM 4
Источник: http://mscrmblog.net/2010/12/09/gene...-report-crm-4/
============== sounds simple dosen’t it - my objective is to run an estimate report and render to PDF all from the click of a button as shown in the screenshot below: ![]() Heres the code – string oppID = Request.QueryString["oppID"].ToString(); ReportingService rs = new ReportingService(); rs.Url = "http://server/reportserver/ReportService.asmx"; System.Net.NetworkCredential creds = new System.Net.NetworkCredential(); creds.Domain = "domain"; creds.UserName = "username"; creds.Password = "password"; rs.Credentials = creds; byte[] result = null; string reportPath = "/CRMORG_MSCRM/4.0/{c6352760-a801-e011-9a31-005056ad3d4b}"; string format = "PDF"; string historyID = null; string devInfo = @"False"; string showHideToggle = null; string encoding; string mimeType; string extension; ParameterValue[] parameterUsed; string[] streamIds; Warning[] warnings = null; ParameterValue[] parameters = new ParameterValue[1]; parameters[0] = new ParameterValue(); parameters[0].Name = "OpportunityID"; // parameter name parameters[0].Value = "{C7DF8F1C-8DF6-DF11-9A31-005056AD3D4B}"; DataSourceCredentials dsc = new DataSourceCredentials(); dsc.DataSourceName = "DataSource1"; dsc.UserName = "C9444B29-E6FC-DF11-9A31-005056AD3D4B"; // SystemuserId from the filteredUser table dsc.Password = "D945754F-C1DF-DF11-81ED-005056AD3D4B"; // OrganizationId from the filteredUser table DataSourceCredentials[] credentials = new DataSourceCredentials[] { dsc }; result = rs.Render(reportPath, format, historyID, devInfo, parameters, credentials, showHideToggle, out encoding, out mimeType, out parameterUsed, out warnings, out streamIds); Response.Clear(); Response.ContentType = "application/pdf"; Response.AddHeader("content-disposition", "attachment; filename=" + Request.QueryString["oppID"].ToString() + ".pdf"); Response.BufferOutput = true; Response.BinaryWrite(result); Response.End(); Response.OutputStream.Flush(); Response.OutputStream.Close(); Response.Flush(); Response.Close(); Deploy aspx to CRM ISV folder — create ISV button to call the ASPX page passing the oppID parameter (being the actual opportunityid) to the page. Источник: http://mscrmblog.net/2010/12/09/gene...-report-crm-4/
