#15 |
На что именно, connector я переустанавливал с разрешением загрузки обновлений...
Может это поможет: Request URL: Ссылкаhttp://ХХХХХХХХХХХХХ/CRMReports/AdHocWizard/SuccessFailurePage.aspx?id=&CRMWRPCToken=I65pVM3aEd6dGgAVXQAGEZ+U6aKFD8eaJf3wsUPSmQ4pbEnjS1X9cfKQMD2yXQNd&CRMWRPCTokenTimeStamp=633946522495619986[/url] Microsoft CRM Unhandled Error Details: Server Error in '/' Application. -------------------------------------------------------------------------------- The request failed with HTTP status 400: Bad Request. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.Net.WebException: The request failed with HTTP status 400: Bad Request. Source Error: An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. Stack Trace: [WebException: The request failed with HTTP status 400: Bad Request.] System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall) +2529 System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters) +275 Microsoft.Crm.ReportingServices2005.ReportingService2005.CreateReport(String Report, String Parent, Boolean Overwrite, Byte[] Definition, Property[] Properties) +191 Microsoft.Crm.Reporting.ReportServer.UploadReport(String path, Byte[] reportDefinition, String name, String description) +390 [CrmReportingException: The request failed with HTTP status 400: Bad Request.] Microsoft.Crm.Reporting.ReportServer.UploadReport(String path, Byte[] reportDefinition, String name, String description) +535 Microsoft.Crm.Reporting.ReportServer.UploadReport(SRSReport report, String reportId, String name, String description) +84 Microsoft.Crm.ObjectModel.ReportService.UploadSRSReport(Guid id, String name, String description, SRSReport srsReport, ExecutionContext context) +300 Microsoft.Crm.ObjectModel.ReportService.CreateInternal(IBusinessEntity entity, Boolean isScheduledReport, ExecutionContext context) +1891 Microsoft.Crm.ObjectModel.ReportService.CreateFromTemplate(String wizardXml, ExecutionContext context) +223 [TargetInvocationException: Exception has been thrown by the target of an invocation.] System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) +0 System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks) +1255 System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) +38 System.Web.Services.Protocols.LogicalMethodInfo.Invoke(Object target, Object[] values) +211 Microsoft.Crm.Extensibility.InternalOperationPlugin.Execute(IPluginExecutionContext context) +160 Microsoft.Crm.Extensibility.PluginStep.Execute(PipelineExecutionContext context) +575 Microsoft.Crm.Extensibility.Pipeline.Execute(PipelineExecutionContext context) +474 Microsoft.Crm.Extensibility.MessageProcessor.Execute(PipelineExecutionContext context) +1859 Microsoft.Crm.Extensibility.InternalMessageDispatcher.Execute(PipelineExecutionContext context) +349 Microsoft.Crm.Extensibility.ExternalMessageDispatcher.Execute(String messageName, Int32 primaryObjectTypeCode, Int32 secondaryObjectTypeCode, PropertyBag fields, CorrelationToken correlationToken, CallerOriginToken originToken, UserAuth userAuth, Guid callerId) +1427 Microsoft.Crm.Sdk.RequestBase.Process(Int32 primaryObjectTypeCode, Int32 secondaryObjectTypeCode, CorrelationToken correlationToken, CallerOriginToken originToken, UserAuth userAuth, Guid callerId) +149 Microsoft.Crm.Sdk.RequestBase.Process(CorrelationToken correlationToken, CallerOriginToken originToken, UserAuth userAuth, Guid callerId) +183 Microsoft.Crm.Sdk.CrmServiceInternal.Execute(RequestBase request, CorrelationToken correlationToken, CallerOriginToken originToken, UserAuth userAuth, Guid callerId) +465 Microsoft.Crm.Sdk.InProcessCrmService.Execute(Object request) +2352 Microsoft.Crm.Application.Platform.ServiceCommands.PlatformCommand.ExecuteInternal() +957 Microsoft.Crm.Application.Platform.DataSource.CreateFromTemplate(String wizardXml) +50 Microsoft.Crm.Web.Reporting.AdHocWizard.SuccessFailurePage.ConfigurePage() +197 Microsoft.Crm.Application.Controls.AppUIPage.OnPreRender(EventArgs e) +28 System.Web.UI.Control.PreRenderRecursiveInternal() +147 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +3548 Basic Server & Client Information: What the End User would have seen: Последний раз редактировалось Soulcar; 24.11.2009 в 12:43. |
