#29 |
А они были включены(я проверял
)...Вот что я вытянул через Log Viewer: Error: Exception has been thrown by the target of an invocation. Error Number: 0x80048298 Error Message: The report definition is not valid. Details: The report definition has an invalid target namespace 'http://schemas.microsoft.com/sqlserver/reporting/2008/01/reportdefinition' which cannot be upgraded. Error Details: The report definition is not valid. Details: The report definition has an invalid target namespace 'http://schemas.microsoft.com/sqlserver/reporting/2008/01/reportdefinition' which cannot be upgraded. Source File: Not available Line Number: Not available Request URL: http://xxxxxxxxxxxxxxxxxxxx/crmrepor...tproperty.aspx Stack Trace Info: [SoapException: The report definition is not valid. Details: The report definition has an invalid target namespace 'http://schemas.microsoft.com/sqlserver/reporting/2008/01/reportdefinition' which cannot be upgraded. ---> The report definition is not valid. Details: The report definition has an invalid target namespace 'http://schemas.microsoft.com/sqlserver/reporting/2008/01/reportdefinition' which cannot be upgraded.] at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall) at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters) at Microsoft.Crm.ReportingServices2005.ReportingService2005.CreateReport(String Report, String Parent, Boolean Overwrite, Byte[] Definition, Property[] Properties) at Microsoft.Crm.Reporting.ReportServer.UploadReport(String path, Byte[] reportDefinition, String name, String description) [CrmReportingException: The report definition is not valid. Details: The report definition has an invalid target namespace 'http://schemas.microsoft.com/sqlserver/reporting/2008/01/reportdefinition' which cannot be upgraded.] at Microsoft.Crm.Reporting.ReportServer.UploadReport(String path, Byte[] reportDefinition, String name, String description) at Microsoft.Crm.Reporting.ReportServer.UploadReport(SRSReport report, String reportId, String name, String description) at Microsoft.Crm.ObjectModel.ReportService.UploadSRSReport(Guid id, String name, String description, SRSReport srsReport, ExecutionContext context) at Microsoft.Crm.ObjectModel.ReportService.CreateInternal(IBusinessEntity entity, Boolean isScheduledReport, ExecutionContext context) [TargetInvocationException: Exception has been thrown by the target of an invocation.] at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at System.Web.Services.Protocols.LogicalMethodInfo.Invoke(Object target, Object[] values) at Microsoft.Crm.Extensibility.InternalOperationPlugin.Execute(IPluginExecutionContext context) at Microsoft.Crm.Extensibility.PluginStep.Execute(PipelineExecutionContext context) at Microsoft.Crm.Extensibility.Pipeline.Execute(PipelineExecutionContext context) at Microsoft.Crm.Extensibility.MessageProcessor.Execute(PipelineExecutionContext context) at Microsoft.Crm.Extensibility.InternalMessageDispatcher.Execute(PipelineExecutionContext context) at Microsoft.Crm.Extensibility.ExternalMessageDispatcher.Execute(String messageName, Int32 primaryObjectTypeCode, Int32 secondaryObjectTypeCode, PropertyBag fields, CorrelationToken correlationToken, CallerOriginToken originToken, UserAuth userAuth, Guid callerId) at Microsoft.Crm.Sdk.RequestBase.Process(Int32 primaryObjectTypeCode, Int32 secondaryObjectTypeCode, CorrelationToken correlationToken, CallerOriginToken originToken, UserAuth userAuth, Guid callerId) at Microsoft.Crm.Sdk.RequestBase.Process(CorrelationToken correlationToken, CallerOriginToken originToken, UserAuth userAuth, Guid callerId) at Microsoft.Crm.Sdk.CrmServiceInternal.Execute(RequestBase request, CorrelationToken correlationToken, CallerOriginToken originToken, UserAuth userAuth, Guid callerId) at Microsoft.Crm.Sdk.InProcessCrmService.Execute(Object request) at Microsoft.Crm.Application.Platform.ServiceCommands.PlatformCommand.ExecuteInternal() at Microsoft.Crm.Application.Platform.ServiceCommands.CreateCommand.Execute() at Microsoft.Crm.Application.Platform.Report.Create(Boolean performDuplicateCheck) at Microsoft.Crm.Application.Forms.AppForm.SaveEntity(EntityProxy entity, FormEventId eventType, String redirectPath, Boolean performDuplicateCheck) |
