#20 |
Сообщение от petr
DAX 5.0.
В печатной форме подтверждения заказа (Sales confirmation -> AOT/Reports/SalesConfirm), в методе fetch() "забыто" изменение значения переменной hasReportBeenPrinted на true, т.е. выделенная скобками bug-fix строчка. X++: boolean fetch()
QueryRun tradeLoopTrans;
boolean hasReportBeenPrinted = false;
setprefix(this.design().caption());
while (custConfirmJour)
setprefix(strfmt("@SYS70899", custConfirmJour.ConfirmId));
while (salesFormLetterReport.moveNextPrintSetting())
if (salesFormLetterReport.checkNextPrintSetting())
element.reset(true);
// All printing must be done in the context of the fetch() method and not
// in the print() method. This ensures printing errors are associated with the
// appropriate documents.
// Bug-fix -->
hasReportBeenPrinted = true;
// Bug-fix <--
// The journalList is used when printing is delayed until after all posting is complete.
if (!journalList.next(custConfirmJour))
break;
// If the report has been printed, return false to indicate the print method should not be run
return (!hasReportBeenPrinted);
}В SP1 проблема не решена. |
| Теги |
| bug report, баг, ошибка, dynamics |
