Старый 11.10.2007, 17:39   #2
Starling is offline
Starling
Дети Юза
530 / 76 (4) ++++
И еще в Event Viewer пишет по этому поводу вот такую гадость:
Object Server 01: The database reported (session 3 (Admin)): [Microsoft][ODBC SQL Server Driver][SQL Server]Line 1: Incorrect syntax near 'tst'.. The SQL statement was: "execute sp_executesql N'UPDATE INVENTSUM SET INVENTSUM.POSTEDQTY = INVENTSUM.POSTEDQTY + INVENTSUMDELTA.SUM_POSTEDQTY, INVENTSUM.POSTEDVALUE = INVENTSUM.POSTEDVALUE + INVENTSUMDELTA.SUM_POSTEDVALUE, INVENTSUM.DEDUCTED = INVENTSUM.DEDUCTED + INVENTSUMDELTA.SUM_DEDUCTED, INVENTSUM.RECEIVED = INVENTSUM.RECEIVED + INVENTSUMDELTA.SUM_RECEIVED, INVENTSUM.RESERVORDERED = INVENTSUM.RESERVORDERED + INVENTSUMDELTA.SUM_RESERVORDERED, INVENTSUM.RESERVPHYSICAL = INVENTSUM.RESERVPHYSICAL + INVENTSUMDELTA.SUM_RESERVPHYSICAL, INVENTSUM.ONORDER = INVENTSUM.ONORDER + INVENTSUMDELTA.SUM_ONORDER, INVENTSUM.ORDERED = INVENTSUM.ORDERED + INVENTSUMDELTA.SUM_ORDERED, INVENTSUM.QUOTATIONISSUE = INVENTSUM.QUOTATIONISSUE + INVENTSUMDELTA.SUM_QUOTATIONISSUE, INVENTSUM.QUOTATIONRECEIPT = INVENTSUM.QUOTATIONRECEIPT + INVENTSUMDELTA.SUM_QUOTATIONRECEIPT, INVENTSUM.REGISTERED = INVENTSUM.REGISTERED + INVENTSUMDELTA.SUM_REGISTERED, INVENTSUM.PICKED = INVENTSUM.PICKED + INVENTSUMDELTA.SUM_PICKED, INVENTSUM.AVAILORDERED = INVENTSUM.AVAILORDERED + INVENTSUMDELTA.SUM_AVAILORDERED, INVENTSUM.AVAILPHYSICAL = INVENTSUM.AVAILPHYSICAL + INVENTSUMDELTA.SUM_AVAILPHYSICAL, INVENTSUM.PHYSICALVALUE = INVENTSUM.PHYSICALVALUE + INVENTSUMDELTA.SUM_PHYSICALVALUE, INVENTSUM.ARRIVED = INVENTSUM.ARRIVED + INVENTSUMDELTA.SUM_ARRIVED, INVENTSUM.PHYSICALINVENT = INVENTSUM.PHYSICALINVENT + INVENTSUMDELTA.SUM_PHYSICALINVENT, INVENTSUM.PHYSICALVALUESECCUR_RU = INVENTSUM.PHYSICALVALUESECCUR_RU + INVENTSUMDELTA.SUM_PHYSICALVALUESECCUR_RU, INVENTSUM.POSTEDVALUESECCUR_RU = INVENTSUM.POSTEDVALUESECCUR_RU + INVENTSUMDELTA.SUM_POSTEDVALUESECCUR_RU, INVENTSUM.LASTUPDDATEPHYSICAL = CASE WHEN INVENTSUM.LASTUPDDATEPHYSICAL > INVENTSUMDELTA.MAX_LASTUPDDATEPHYSICAL THEN INVENTSUM.LASTUPDDATEPHYSICAL ELSE INVENTSUMDELTA.MAX_LASTUPDDATEPHYSICAL END , INVENTSUM.LASTUPDDATEEXPECTED = CASE WHEN INVENTSUM.LASTUPDDATEEXPECTED > INVENTSUMDELTA.MAX_LASTUPDDATEEXPECTED THEN INVENTSUM.LASTUPDDATEEXPECTED ELSE INVENTSUMDELTA.MAX_LASTUPDDATEEXPECTED END , INVENTSUM.CLOSEDQTY = CASE WHEN ((INVENTSUM.POSTEDQTY + INVENTSUMDELTA.SUM_POSTEDQTY) = 0 AND (INVENTSUM.DEDUCTED + INVENTSUMDELTA.SUM_DEDUCTED) = 0 AND (INVENTSUM.PICKED + INVENTSUMDELTA.SUM_PICKED) = 0 AND (INVENTSUM.RECEIVED + INVENTSUMDELTA.SUM_RECEIVED) = 0 AND (INVENTSUM.REGISTERED + INVENTSUMDELTA.SUM_REGISTERED) = 0 AND (INVENTSUM.RESERVPHYSICAL + INVENTSUMDELTA.SUM_RESERVPHYSICAL) = 0 AND (INVENTSUM.RESERVORDERED + INVENTSUMDELTA.SUM_RESERVORDERED) = 0 AND (INVENTSUM.ONORDER + INVENTSUMDELTA.SUM_ONORDER) = 0 AND (INVENTSUM.ORDERED + INVENTSUMDELTA.SUM_ORDERED) = 0 AND (INVENTSUM.ARRIVED + INVENTSUMDELTA.SUM_ARRIVED) = 0 AND (INVENTSUM.QUOTATIONISSUE + INVENTSUMDELTA.SUM_QUOTATIONISSUE) = 0 AND (INVENTSUM.QUOTATIONRECEIPT + INVENTSUMDELTA.SUM_QUOTATIONRECEIPT) = 0) THEN 1 ELSE 0 END,INVENTSUM.CLOSED = CASE WHEN ((INVENTSUM.POSTEDQTY + INVENTSUMDELTA.SUM_POSTEDQTY) = 0 AND (INVENTSUM.DEDUCTED + INVENTSUMDELTA.SUM_DEDUCTED) = 0 AND (INVENTSUM.PICKED + INVENTSUMDELTA.SUM_PICKED) = 0 AND (INVENTSUM.RECEIVED + INVENTSUMDELTA.SUM_RECEIVED) = 0 AND (INVENTSUM.REGISTERED + INVENTSUMDELTA.SUM_REGISTERED) = 0 AND (INVENTSUM.RESERVPHYSICAL + INVENTSUMDELTA.SUM_RESERVPHYSICAL) = 0 AND (INVENTSUM.RESERVORDERED + INVENTSUMDELTA.SUM_RESERVORDERED) = 0 AND (INVENTSUM.ONORDER + INVENTSUMDELTA.SUM_ONORDER) = 0 AND (INVENTSUM.ORDERED + INVENTSUMDELTA.SUM_ORDERED) = 0 AND (INVENTSUM.ARRIVED + INVENTSUMDELTA.SUM_ARRIVED) = 0 AND (INVENTSUM.QUOTATIONISSUE + INVENTSUMDELTA.SUM_QUOTATIONISSUE) = 0 AND (INVENTSUM.QUOTATIONRECEIPT + INVENTSUMDELTA.SUM_QUOTATIONRECEIPT) = 0 AND (INVENTSUM.POSTEDVALUE + INVENTSUMDELTA.SUM_POSTEDVALUE) = 0 AND (INVENTSUM.PHYSICALVALUE + INVENTSUMDELTA.SUM_PHYSICALVALUE) = 0) THEN 1 ELSE 0 END FROM (SELECT SUM(POSTEDQTY) AS SUM_POSTEDQTY, SUM(POSTEDVALUE) AS SUM_POSTEDVALUE, SUM(DEDUCTED) AS SUM_DEDUCTED, SUM(RECEIVED) AS SUM_RECEIVED, SUM(RESERVORDERED) AS SUM_RESERVORDERED, SUM(RESERVPHYSICAL) AS SUM_RESERVPHYSICAL, SUM(ONORDER) AS SUM_ONORDER, SUM(ORDERED) AS SUM_ORDERED, SUM(QUOTATIONISSUE) AS SUM_QUOTATIONISSUE, SUM(QUOTATIONRECEIPT) AS SUM_QUOTATIONRECEIPT, SUM(REGISTERED) AS SUM_REGISTERED, SUM(PICKED) AS SUM_PICKED, SUM(AVAILORDERED) AS SUM_AVAILORDERED, SUM(AVAILPHYSICAL) AS SUM_AVAILPHYSICAL, SUM(PHYSICALVALUE) AS SUM_PHYSICALVALUE, SUM(ARRIVED) AS SUM_ARRIVED, SUM(PHYSICALINVENT) AS SUM_PHYSICALINVENT, SUM(PHYSICALVALUESECCUR_RU) AS SUM_PHYSICALVALUESECCUR_RU, SUM(POSTEDVALUESECCUR_RU) AS SUM_POSTEDVALUESECCUR_RU, MAX(LASTUPDDATEPHYSICAL) AS MAX_LASTUPDDATEPHYSICAL, MAX(LASTUPDDATEEXPECTED) AS MAX_LASTUPDDATEEXPECTED, INVENTSUMDELTA.ITEMID, INVENTSUMDELTA.INVENTDIMID FROM INVENTSUMDELTA WHERE INVENTSUMDELTA.DATAAREAID = @p1 AND INVENTSUMDELTA.TTSID = @p2 AND INVENTSUMDELTA.ISAGGREGATED = 0 GROUP BY INVENTSUMDELTA.ITEMID, INVENTSUMDELTA.INVENTDIMID) AS INVENTSUMDELTA WHERE INVENTSUM.DATAAREAID = @p1 AND INVENTSUM.ITEMID = INVENTSUMDELTA.ITEMID AND INVENTSUM.INVENTDIMID = INVENTSUMDELTA.INVENTDIMID',N'@p1 NVARCHAR(3), @p2 BIGINT',@p1='tst', @p2=''tst''"
For more information, see Help and Support Center at
tst - название компании
ax4.0
Ошибка при разноске касс (только по кредиту) через общий журнал Aquarius DAX: Функционал 12 28.01.2008 20:13
Сумма и количество складских проводок при разноске складских журналов vasiliy DAX: Программирование 0 04.08.2005 11:04
Ошибка при разноске журнала переноса ATimTim DAX: Функционал 5 01.09.2004 15:24
Ошибка при разноске Инвентаризации dyatlowsky DAX: Функционал 2 01.06.2004 11:29
Часовой пояс GMT +3, время: 01:39.
