Старый 22.11.2006, 19:51   #14
Sirius is offline
Sirius
В курсе Installation & Configuration (код 8332) написано
Instead of configuring the batch server as a regular client, configure it with enough CPU and memory to run as an AOS. This gives you a backup AOS server in the event one of your current AOSs fail, or you need to scale out more - you have a server ready and waiting to provide additional online capablityfor your users, when needed
т.е. написано что можно сконфигурировать как batch server сам AOS, но как - не написано.. может кто знает как сделать такую хитрость.
faq, пакет, пакетная обработка, пакетное задание
axaptapedia: Batch processing Blog bot DAX Blogs 0 29.01.2009 17:05
Fred Shen: New server-based batch framework in AX2009 Blog bot DAX Blogs 0 04.09.2008 07:06
axaptabuilder: How to setup Axapta batch server running as user defined windows service Blog bot DAX Blogs 0 12.04.2007 16:10
axaptabuilder: How to setup Axapta batch server running as user defined windows service Blog bot DAX Blogs 0 28.10.2006 16:47
Часовой пояс GMT +3, время: 19:11.
