Старый 04.09.2008, 07:06   #1
Fred Shen: New server-based batch framework in AX2009
Источник: http://fredshen.spaces.live.com/Blog...E4E3!227.entry
Microsoft Dynamics AX 2009 introduces a new batch framework that supports server-based batches without the need for a client. All new batch jobs in Microsoft Dynamics AX 2009 use the new batch framework. Most existing batch jobs from previous releases are being migrated to the new framework. Client-side batches are supported in Microsoft Dynamics AX 2009 but are not recommended.
From AX2009, we don't need to run a client to run scheduled jobs, if you specify that the batch job runs on server.
The batch job runs on server by default unless the developer overrides the runImpersonated method and make it return false.
The old client-based batch processing is still in ax 2009 for backward compatibility and will be removed in future versions. The old client-based batch system, that was based on a dedicated client, cannot be replaced at this stage.
For example, due to some technical problems that the compiler cannot be run on the server tier, which means the task to run a scheduled compiling application or updating cross-reference must be run on client-tier.
пакетное задание, ax2009
axaptapedia: Batch processing Blog bot DAX Blogs 0 29.01.2009 17:05
axaptabuilder: How to setup Axapta batch server running as user defined windows service Blog bot DAX Blogs 0 12.04.2007 16:10
axaptabuilder: How to setup Axapta batch server running as user defined windows service Blog bot DAX Blogs 0 28.10.2006 16:47
Fred Shen: Convert Axapta date type value to datetime type value in SQL Server Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 10:56.
