Старый 08.09.2006, 16:07   #12
Yprit is offline
Yprit
Аватар для Yprit
419 / 93 (4) ++++
По-моему, нет. Это вообще-то для Intercompany функционал, я с ним плотно не сталкивался. Цитата из доки:
3.1 External Codes
External codes are created using the External codes form, which lists external identifiers of values in the intercompany organization. The form can be accessed from various base data forms. To create external code types, you must specify a code type, a description for the code type, and the value. Refer to the online help for step-by-step instructions on how to create external codes for customers, vendors, items, units, currencies and so on.
Examples of when to use external codes:
• Your trade partner requests identifiers for countries other than those defined in the Country form.
In this case, create external codes for the countries in the External codes form accessed from the Country form.
• Your company has defined one item number with several item dimension combinations attached but your trade partner has defined one item number per item combination.
In this case, create external codes for the item dimension combinations in the External codes form accessed from the Item dimension combination form.
You can create several external codes for the same item, company account, unit, currency, country and so on. For example, if there are several standards for the same country code, you can create the standards, you use, and enter the values according to the standards. The value of a code will be transferred to the documents.
Поищите по форуму, кажется очень давно Елена Сысовская выкладывала вордовский файл по настройке Intercompany, где это было описано.
extcodevaluetable, внешние коды, ax3.0
Внешние коды для единиц измерения номенклатуры IIS DAX: Функционал 9 01.04.2005 16:36
ОС. Структура и еще кое-что про коды ОКОФ dimit DAX: Функционал 6 12.11.2004 13:53
Коды клиентов в CRM - проблема Zabr DAX: Функционал 5 01.12.2003 12:41
внешние коды Dana DAX: Функционал 3 30.04.2003 12:19
Часовой пояс GMT +3, время: 15:46.
