#10 |
да лехко
DEV ********* Large buffer read ************** LargeBufferReads: Selected 1000 records in 370ms. ********* Test run with 10000 Records ************** Insert : 3498 Select on ClusteredIndex : 888 Select on Unique index with cache hit: 110 Select on Unique index without cache hit : 6933 Select on Non-unique index : 7891 Tempdb Temp table Inserts : 813, Selects : 61 inMemory Temp table (AOS) Inserts : 818, Selects : 75 SGOC Inserts : 6874, SGOC Lookups (25) times each entry : 576 Update : 10951 Inserts thru recordInsertList : 3360 Insert RecordSet : 560 Update RecordSet : 543 Delete From : 4611 SANDBOX ********* Large buffer read ************** LargeBufferReads: Selected 1000 records in 1611ms. ********* Test run with 10000 Records ************** Insert : 26555 Select on ClusteredIndex : 10094 Select on Unique index with cache hit: 125 Select on Unique index without cache hit : 100669 Select on Non-unique index : 100839 Tempdb Temp table Inserts : 959, Selects : 75 inMemory Temp table (AOS) Inserts : 913, Selects : 81 SGOC Inserts : 90174, SGOC Lookups (25) times each entry : 416 Update : 128997 Inserts thru recordInsertList : 27578 Insert RecordSet : 1499 Update RecordSet : 1095 Delete From : 1153
-ТСЯ или -ТЬСЯ ? |
Теги |
performance, performance test tool |
Опции просмотра | |
