mfp: SysExtension Framework – to the rescue
Источник: http://blogs.msdn.com/b/mfp/archive/...he-rescue.aspx
============== There is a coding pattern that has been proliferating the X++ code base for years. It is not an X++ best practices – nor is it object oriented; yet it is used quite heavily (unfortunately). Consider a simple class hierarchy with an abstract base class and 3 derived classes. A typical implementation of a factory would be a static method on the base class, like this: (Please ignore the type of the parameter – it could be anything, I choose str for simplicity) Now; the problems with this approach are many.
SysExtension Framework to the rescue. Consider you decorate the subclasses with an attribute, like depicted here: Then you can rewrite the factory method to this: The extension framework returns an instance of the right subclass automatically. It uses the attribute to determine which subclass instance to create. Quite simple – extraordinary powerful! Now notice:
To learn more about the SysExtension framework see here. ============== Источник: http://blogs.msdn.com/b/mfp/archive/...he-rescue.aspx
| Теги |
| sysextension |
