emeadaxsupport: Slow performance when Configuration key turned off
Источник: http://blogs.msdn.com/b/axsupport/ar...urned-off.aspx
============== Description: The configuration key Sales tax (ledgerbasicSalesTax) has been turned off in the system. When running example the retail statement posting, the performance is very poor. The slow response is originated in every call to TaxParameters::find(). When analyzing the sql server queries we see a large number of Temporary table been generated which all take 150-200 msec. Reason: By design: We have explained what is happening in this article. http://msdn.microsoft.com/en-us/library/bb314749.aspx TempDB Tables for Disabled Tables You can disable a regular persisted database table by disabling the configuration key that controls the table. Disabling the key causes the system to automatically create a TempDB style of temporary table that matches the fields and schema of the database table. This temporary table exists in the underlying SQL Server database and is managed by the Application Object Server (AOS). The purpose of automatically creating this TempDB table is to enable AOT objects that reference the disabled table to continue to compile and run. You can read and write to this TempDB table even though the configuration key is disabled. All table buffer variables inherit the methods of the xRecord class. One such method is setTmp, which creates an InMemory temporary table that has the same schema as the regular table. However, the setTmp method cannot create an InMemory table from a TempDB table. You can call the method isTempDb to determine whether the setTmp method is available. Solution: Turn it on again. In the example with sales tax use a tax percentage of 0,00% instead Author: Kim Truelsen Date: 25/11-2013 Источник: http://blogs.msdn.com/b/axsupport/ar...urned-off.aspx
Кстати прикольная тема
т.е. по сути советуют не отключать ключи на которых могут быть завязаны какие-нибудь таблицы. а поскольку сложно понять что завязано, а что нет, то надо иметь все ключи включенными у кого-нибудь есть идеи как с этим бороться? |
бороться с чем? вроде в статье есть Solution простой
ну описанное solution - если вы отключили ключ, включите его.
причем приведен один пример, но такое же и будет с какими-нибудь RetailParameters, smmParameters и так далее т.е. все это тоже придется включать |
Насколько я понимаю, проблема в том, что раньше было два типа таблиц - постоянные и временные (Regular и InMemory в терминологии AX 2012), и в куче мест проверка !buf.IsTmp() означала по сути проверку на то, является ли таблица постоянной. Потом добавили новый тип таблиц - TempDB, а кучу кода, который знал лишь про два прежних типа таблиц, не поменяли, вот этот код и сломался, поскольку теперь !buf.isTmp() не тождественно проверке на то, что "актуальный" тип таблицы - Regular.
Лежащий на поверхности способ подправить ситуацию - это приделать костылик в метод Company::createParameter(), который бы перед попыткой вставить запись проверял, какой у таблицы тип в AOT (Regular/InMemory/TempDB) и какой "актуальный" тип (isTmp(), isTempDB()), и пытался создать запись лишь в том случае, если таблица и задумана, и по факту является постоянной. Ну и, возможно, кэшировать результата этой проверки... |
| За это сообщение автора поблагодарили: trud (1). | |
ну костылик поможет только частично
вот например код из smmParametersTable. при реализации костылика все равно будет выполняться X++: select firstonly parametersTable index key where parametersTable.Key == 1; вообще непонятна идея переводить отключенные таблицы на tempdb, чем просто временные не устраивали X++: public server static smmParametersTable find(boolean _forupdate = false) { smmParametersTable parametersTable = null; ; if (parametersTable.isTmp()) { return parametersTable; } parametersTable.selectForUpdate(_forupdate); // Find paramters table select firstonly parametersTable index key where parametersTable.Key == 1; // If paramters table is not found it is created if (!parametersTable && !parametersTable.isTmp()) { // Use the generic framework for creating the parameters table Company::createParameter(parametersTable); //NumberSeqReference::construct(smmParametersTable::numberSeqModule()).load(); } return parametersTable; } |
