Старый 07.07.2022, 19:13   #1
Alexdmeyer: How to Use a .NET Project Within a D365FO Solution
Источник: https://alexdmeyer.com/2022/07/07/ho...65fo-solution/
I wanted to write today about why I utilize .NET projects for certain scenarios when developing X++ solutions for D365FO. How Is This Possible? How is it possible that you can have two different project types under one solution? I actually wrote about the changes that were happening to the X++ compiler way back in […]
The post How to Use a .NET Project Within a D365FO Solution appeared first on Alex Meyer.
Alexdmeyer: How to Apply D365FO Extensible Data Security Based on the Current User Blog bot DAX Blogs 0 21.06.2021 18:13
alexef: Example about use Warehouse Physical Inventory Journal and Configuration Package in Business Central SaaS/Cloud version Blog bot NAV: Blogs 0 13.12.2018 16:11
emeadaxsupport: How General Budget Reservations will update Committed Cost on Project Contracts Blog bot DAX Blogs 0 21.05.2015 21:12
fed: Net requirements update in MRP Module and Working Set of MRP Blog bot DAX Blogs 14 08.05.2012 13:09
Nav developer: Beginners guide: How connect to NAV from a .net project, using C/Front Blog bot Dynamics CRM: Blogs 0 19.04.2008 12:28
Часовой пояс GMT +3, время: 12:36.
