Старый 23.09.2020, 15:11   #1
crmtipoftheday: Tip #1384: Inline Code in Power Automate
Источник: https://crmtipoftheday.com/1384/inli...power-automate
I finally found some courage to publish a video tip of my own. Why now? Because the topic is just too good to simply write it down. You have to see it! What is it? It’s JavaScript code inside Power Automate – yes, we can!
Watch this video to learn how to build the simplest possible Azure Function that will bring inline code execution to your flows! The possibilities are endless – regular expressions, recursive functions, math operations, and much more.
WATCH VIDEO
crmtipoftheday: Tip #1363: Get Environment Variables in Power Automate (and Power Apps) Blog bot Dynamics CRM: Blogs 0 09.06.2020 23:17
crmtipoftheday: Tip #1362: Trigger Power Automate on Associate / Disassociate Blog bot Dynamics CRM: Blogs 0 08.06.2020 14:11
crmtipoftheday: Tip #1359: Whose fault is it in Power Automate? Blog bot Dynamics CRM: Blogs 0 03.06.2020 11:11
crmtipoftheday: Tip #1350: Modify webhook return status as needed in Power Automate Blog bot Dynamics CRM: Blogs 0 05.05.2020 18:13
Часовой пояс GMT +3, время: 06:34.
