Старый 23.12.2019, 10:58   #1
Ventainais is offline
Ventainais
Hide, show dialog query select button.
Greetings!
I'm creating a new report and added to it a datasource.
The report is run from extended RunBaseReport Class and in the dialog method
I create a dialog in witch I added an enum type combobox.
What I am trying to do is hide the select button depending on what value the user has selected.
public Object dialog(Object _dialog)
    InventFertilizerReportDesign    inventFert;
    dlg     = super(_dialog);
    dlgFldDesignVal     = dlg.addField(typeId(InventFertilizerReportDesign), "@LVT76");
    dlgFldDesignVal.value(reportDesign);
    dlgFldDateFrom      = dlg.addField(typeId(TransDate), "@SYS5209");
    dlgFldDateFrom.value(dateFrom);
    dlgFldDateTo        = dlg.addField(typeId(TransDate), "@SYS80662");
    dlgFldDateTo.value(datoTo);
    dlgFldShopId        = dlg.addField(typeId(ReShopId));
    dlgFldShopId.value(shopId);
    dlgFldShowPrice     = dlg.addField(typeId(NoYes), "@LVT4117");
    dlgFldShowWeight    = dlg.addField(typeId(NoYes), "@LVT4119");
    return dlg;
In method "dialogPostRun" I set controlMethodOverload to true
super(dialog);
    dialog.dialogForm().formRun().controlMethodOverload(true);
    dialog.dialogForm().formRun().controlMethodOverloadObject(this);
public int Fld6_1_selectionChange()
    int     ret;
    Object          mainFormGroupOrig;
    Object  control = dlg.formRun().controlCallingMethod();
    ret = control.selectionChange();
    switch (dlgFldDesignVal.value())
        case InventFertilizerReportDesign::AmmoniaNitrateDesign :
            showQueryValues = true;
            dlgFldDateFrom.visible(true);
            dlgFldDateTo.visible(true);
            dlgFldShopId.visible(true);
            dlgFldShowPrice.visible(false);
            dlgFldShowWeight.visible(false);
            break;
        case InventFertilizerReportDesign::SalesReport          :
            showQueryValues = false;
            dlgFldDateFrom.visible(false);
            dlgFldDateTo.visible(false);
            dlgFldShopId.visible(false);
            dlgFldShowPrice.visible(true);
            dlgFldShowWeight.visible(true);
            break;
    reportDesign = dlgFldDesignVal.value();
    return ret;
 public boolean showQueryValues()
    return showQueryValues;
as simple it may be I can't figure out how to hide or show the button.
Старый 23.12.2019, 11:28   #2
Pandasama is offline
Pandasama
465 / 140 (5) +++++
Сообщение от Ventainais Посмотреть сообщение
try method .showQuerySelectButton() instead
Старый 23.12.2019, 11:31   #3
Pandasama
465 / 140 (5) +++++
though if you want to hide/show this element in runtime - i think, not showQueryValues(), not showQuerySelectButton() cant help you - i'm almost sure than this methods processed just once, when dialog opened
i think, you must get object for button control (may be by modify RunBase method where this button is created, or maybe RunBase already have variable for this button) and change this object visible property
Последний раз редактировалось Pandasama; 23.12.2019 в 11:46.
Старый 23.12.2019, 11:33   #4
VORP is offline
VORP
Аватар для VORP
147 / 95 (4) ++++
Method showQueryValues is called upon dialog initialization(/Classes/RunBaseDialogModify/Methods/init - (623, 10)), depending on it query button will be added. So if you modify it when dialog already initialized nothing happens. You should hide button manually, maybe looking at initQuery methods will be useful. But event after that you need to reset query if required, because it will be used even if its invisible.
Старый 23.12.2019, 11:34   #5
Ventainais
public boolean showQueryValues() won't help to.
Старый 23.12.2019, 11:36   #6
Ventainais
Thank you Pandasama and VORP.
I'll try to figure out what could be done.
Старый 27.12.2019, 14:48   #7
Ventainais
One solution I have
    #define.GroupQueryPrinter('GroupQueryPrinter')
    #define.RightButtonGrp('RightButtonGrp')
    formRun = dlg.dialogForm().formRun();
    queryGroupCtrl = formRun.design().controlName(#GroupQueryPrinter);
    if (queryGroupCtrl)
        queryGroupCtrl.controlNum(1).visible(showQryVal);
    queryGroupCtrl = formRun.design().controlName(#RightButtonGrp);
    if (queryGroupCtrl)
not recommended but for my project it works.
This hides the query value field group and the select button.
axapta 2012, hide, select button, show
emeadaxsupport: Microsoft Dynamics AX general performance analysis scripts page 5 Blog bot DAX Blogs 0 01.09.2014 14:11
dynamicscare: Using Power BI to Analyze Your Dynamics AX Data Blog bot DAX Blogs 1 06.10.2013 18:11
daxline: How to show or hide query ranges on dialogs in Dynamics AX? Blog bot DAX Blogs 0 03.08.2011 09:11
Часовой пояс GMT +3, время: 08:37.
