Старый 03.12.2019, 19:15   #1
Navigate Into Success: Control Add-ins Supercharged: Automating gulp.watch
Источник: http://vjeko.com/control-add-ins-sup...ng-gulp-watch/
Yesterday you’ve seen how to use gulp to make it do something truly useful: bundling your JavaScript and CSS files. Introducing gulp for the purpose of bundling your files allows you to split your functionality into as many files as you want, but use only a single script and a single stylesheet file from your control add-in. That way you not only optimized how your browser loads the files, but you also eliminated the need to maintain your controladdin object file every single time a new JavaScript or CSS file is added (or an existing one is removed).
However, you still need to run gulp build every single time you want to build your bundles. If you forget that, your controladdin will not be updated with your changes.
Thankfully, gulp has an answer to this: the gulp.watch feature. That’s the topic of my next demo, that I’ve explained in the 05-gulp-watch branch of my supercharged-01 repository.
The Readme.md file of that branch explains how to configure the watch task in the gulpfile.js file, and how to configure VS Code to automatically run the watch task every time you open the workspace. Once you follow those instructions, you can work on individual JavaScript or CSS files without the need to run gulp build or to maintain your controladdin object file. The former is taken care of by gulp, and the latter is taken care by… well, gulp too. Gulp is cool, really
Read this post at its original location at http://vjeko.com/control-add-ins-sup...ng-gulp-watch/, or visit the original blog at http://vjeko.com. 5e33c5f6cb90c441bd1f23d5b9eeca34The post Control Add-ins Supercharged: Automating gulp.watch appeared first on Vjeko.com.
Navigate Into Success: Control Add-ins Supercharged: Teaching gulp some useful tricks Blog bot NAV: Blogs 0 03.12.2019 06:21
Navigate Into Success: Control Add-ins Supercharged: Hello, gulp! Blog bot NAV: Blogs 0 29.11.2019 17:11
Navigate Into Success: Control Add-ins Supercharged – Kicking off Blog bot NAV: Blogs 0 27.11.2019 06:24
Navigate Into Success: Automating control add-in development using gulp Blog bot NAV: Blogs 0 17.01.2019 22:12
Navigate Into Success: Deploying control add-ins during development in NAV 2016 Blog bot Dynamics CRM: Blogs 0 13.11.2015 10:00
Часовой пояс GMT +3, время: 15:26.
