Старый 02.11.2019, 00:16   #1
stoneridgesoftware: What You Need to Know About Dynamics 365 Finance and Operations ‘One Version’ and Development and Build Environments
Источник: https://stoneridgesoftware.com/what-...-environments/
We’ve provided some previous resources on how the more frequent updates to Dynamics 365 Finance and Operations ‘One Version’ affects users and your active system. However, you also need to consider how One Version affects your Development and Build environments too. Here is a couple of scenarios for how your instance could be set up with Microsoft and what your options are.
Scenario 1:
Microsoft standard offer with Microsoft subscription: three environments
  1. Your production environment
  2. a Tier-2 Standard Acceptance Test environment (UAT/Sandbox), and
  3. One Tier-1 develop and test environment.*
*Assume your Build server is hosted on your Azure subscription.
Scenario 2:
Production, Dev Current Release, Dev Next Release, UAT Sandbox Current Release, UAT Next Release Build
The big takeaway of this concept is Microsoft is keeping your one SANDBOX and your PRODUCTION up-to-date. You are responsible for keeping your Development and Build environments updated.
So, what about your Development environment(s), and your Build environment, or your other UAT/Sandbox environment(s)?
Consider you have D365 Finance and Operations operating per scenario 1 above, where you have only one Sandbox environment and your SANDBOX is now on the newest and greatest version. It was updated by Microsoft per your Update settings in your LCS project settings. Your user then ran into an issue in PRODUCTION. You now don’t have a SANDBOX to refresh PRODUCTION to nor a SANDBOX environment that is a copy of PRODUCTION for you to do your testing and troubleshooting.
When your SANDBOX is at the new version with scenario 1’s topology, be aware that the code on your development environment (and build environment), will not have a SANDBOX environment to be pushed to since your SANDBOX and development and build versions are different. So, it is important that you keep the version in synch between all your environments
In order to avoid the above dilemma, you may choose to implement a code freeze period, concentrate on testing the new SANDBOX so you can get PROD updated to the new version on a timely manner and continue with code work. Also, another factor to be aware of is that you can hold off the One Version update for only so long. Or alternatively, you can implement an environment similar to scenario 2 above and have another Sandbox environment that is at the same version as PROD, Dev and Build environments. Scenario 2 will be an added cost to you and the cost will depend on the number of environments and the type of your subscription.
Lastly, when your PRODUCTION environment has been updated, consider updating your DEV and BUILD environments in a timely manner so you can continue with code work.
stoneridgesoftware: The Four Steps to Upgrade from Dynamics AX to Dynamics 365 Finance and Operations Blog bot DAX Blogs 0 12.02.2019 19:11
yetanotherdynamicsaxblog: Considerations when "upgrading" Dyn365FO from 8.0 to 8.1 Blog bot DAX Blogs 0 26.11.2018 05:01
everythingdynamicsaxbi: Reporting in Dynamics 365 for Finance and Operations – The definitive guide Blog bot DAX Blogs 0 02.11.2017 22:11
Часовой пояс GMT +3, время: 09:09.
