Старый 06.02.2019, 00:25   #1
goshoom: String format options for utcDateTime
Источник: http://dev.goshoom.net/en/2019/02/st...r-utcdatetime/
I’ve run into a problem that reminded me that while X++ types and corresponding CLR types (such as str and System.String) can often be user interchangeably, they aren’t the same.
I was trying to convert a utcdatetime value to the standard “sortable” format in D365FO, for which I wrote the following code:
utcdatetime currentDateTime = DateTimeUtil::utcNow();str s = System.String::Format('{0:s}', currentDateTime);
What I expected was something like 2019-02-03T17:29:00, but I got a very different format – 02/03/2019 17:29:00. What was wrong with my code?
The format definition is all right… but I don’t have the right type! I can easily fix the problem by declaring currentDateTime as System.DateTime instead of utcdatetime.
System.DateTime currentDateTime = DateTimeUtil::utcNow();str s = System.String::Format('{0:s}', currentDateTime);
When Format() method is called, it’s able to utilize special formatting options (such as the “s” format), if the type of the value has methods that knows what do to it with it. System.DateTime knows what to do, but utcdatetime is actually Microsoft.Dynamics.Ax.Xpp.AxShared.utcdatetime structure which isn’t able to handle these options. It has a single hard-coded format for converting the datetime value to a string.
While I’m still working with the same value in both utcdatetime and System.DateTime, they’re two different types with different behavior and a conversion may be needed if I need behavior specific to only one of them.
I tested this behavior on Platform Update 22 and 24.
goshoom: Connection string for LINQ to SQL Blog bot DAX Blogs 0 21.03.2015 23:17
goshoom: Custom date and time format Blog bot DAX Blogs 0 30.01.2015 01:15
paruvella: De-serialization of string format XML in Dynamics Ax Blog bot DAX Blogs 0 08.10.2010 14:05
paruvella: De-serialization of string format XML in Dynamics Ax Blog bot DAX Blogs 0 29.09.2010 18:05
paruvella: De-serialization of string format XML in Dynamics Ax Blog bot DAX Blogs 0 21.07.2010 22:06
Часовой пояс GMT +3, время: 17:16.
