Старый 17.12.2018, 15:12   #1
alirazazaidi: Custom lookup field and group reference field D365 for finance and operations
Источник: https://www.tech.alirazazaidi.com/cu...nd-operations/
Hi all following code snippet for custom lookup. Copy the onlookup event handler and copy in extension class and the following code snippet
Field based
[FormControlEventHandler(formControlStr(Txxxx, Txxxx_ChildName), FormControlEventType::Lookup)]
public static void xxxxx_DssChildName_OnLookup(FormControl sender, FormControlEventArgs e)
Query query = new Query();
QueryBuildDataSource qbds;
QueryBuildDataSource qbdsJoin;
SysTableLookup sysTableLookup = sysTableLookup::newParameters(tableNum(DirPartyTable), sender);
qbds= query.addDataSource(tableNum(DirPartyTable));
qbdsJoin= qbds.addDataSource(tableNum(DirPartyRelationship));
//qbdsJoin.relations( false);
//qbdsJoin.fields().dynamic(NoYes::Yes);
// hcmWorkerCaller = HcmWorker::find(currentWorker());
// qbds.addRange(fieldNum(DirPartyTable, RecId)).value(int642Str(HcmWorker::find(currentWorker()).Person));
qbdsJoin.addRange(fieldNum(DirPartyRelationship, parentparty)).value(int642Str(HcmWorker::find(currentWorker()).Person));
qbdsJoin.addLink(fieldNum(DirPartyTable, RecId), fieldNum(DirPartyRelationship, childparty));
qbdsJoin.joinMode(JoinMode::InnerJoin);
sysTableLookup.parmQuery(query);
sysTableLookup.addLookupfield(fieldNum(DirPartyTable, Name), true);
sysTableLookup.addLookupfield(fieldNum(DirPartyTable, RecId));
sysTableLookup.performFormLookup();
FormControlCancelableSuperEventArgs event = e as FormControlCancelableSuperEventArgs;
event.CancelSuperCall();
Reference based is as follow
[FormControlEventHandler(formControlStr(xxxxx, Txeee_dddd), FormControlEventType::Lookup)]
public static void ddddee_DSSPerson_OnLookup(FormControl sender, FormControlEventArgs e)
SysReferenceTableLookup _sysTableLookup = SysReferenceTableLookup::newParameters(tableNum(DirPartyTable), sender);
_sysTableLookup.parmQuery(query);
_sysTableLookup.addLookupfield(fieldNum(DirPartyTable, Recid));
_sysTableLookup.addLookupfield(fieldNum(DirPartyTable, Name));
//, true);
// _sysTableLookup.addLookupfield(fieldNum(DirPartyTable, recid));
_sysTableLookup.performFormLookup();
alirazazaidi: Parent child form Customization D365 for Finance and Operations Blog bot DAX Blogs 0 21.01.2018 16:14
powerobjects: Dynamics 365 Development and Customization: Field Group Extensions Blog bot Dynamics CRM: Blogs 0 10.01.2018 05:11
atinkerersnotebook: Creating New Customer Notifications for Dynamics 365 for Operations using Flow and the Common Data Service Blog bot DAX Blogs 0 15.12.2016 22:12
Часовой пояс GMT +3, время: 12:09.
