Старый 19.10.2018, 14:11   #1
emeadaxsupport: Inspecting a D365FO Meta Data Hotfix Content
Источник: https://blogs.msdn.microsoft.com/axs...otfix-content/
In this article, you will find detailed instructions, on how to inspect content of a D365FO meta data hotfix. The article describes a manual approach as well as running PowerShell scripts to extract the underlying dependencies of hotfixes and affected objects. All descriptions are in attached “Inspecting a D365FO Meta Data Hotfix Content.docx” document. Inspecting-a-D365FO-Meta-Data-Hotfix-Content... Read more
stoneridgesoftware: Automated Data Entity Import Using DIXF in Dynamics AX Blog bot DAX Blogs 0 07.08.2017 20:19
patrickmouwen: 1yr with AX7 Data Management – My top 12 learnings Blog bot DAX Blogs 2 12.10.2016 15:14
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
Мелкомягкий CRM: Панель управления для MS CRM с помощью Reporting Services Blog bot Dynamics CRM: Blogs 1 24.08.2009 14:41
Часовой пояс GMT +3, время: 14:48.
