Старый 13.10.2016, 12:11   #1
organicax: Vendor invoice expenditure reviewers
Источник: https://organicax.com/2016/10/13/ven...ure-reviewers/
If you are looking to use vendor invoices and specifically approval workflow. You’ll need to work out who should approve the invoice. If they are expense type invoices then one option is to use financial dimensions. Based on the dimension allocated to the invoice then it would assign the approver as the owner of that dimension.
You can set this up with the vendor invoice expenditure reviewers. It will require some additional configuration like assigning an owner to a dimension value and configuring the invoice workflow to use the participant provider for vendor invoice expenditure participants.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Accounts payable, General ledger
organicax: cXML punchOut protocol handler for AX2012 Blog bot DAX Blogs 0 27.09.2016 14:11
organicax: cXML punchout protocol handler installation for AX2012 R3 Blog bot DAX Blogs 0 27.09.2016 14:11
organicax: WMS Mobile Device indirect menu items – compile of posts. Blog bot DAX Blogs 0 03.09.2016 01:24
organicax: Warehouse mobile device text colors some additional notes on setup Blog bot DAX Blogs 0 25.03.2016 12:11
emeadaxsupport: AX2012 purchasing posting types “Purchase Expenditure for product” and “Purchase expenditure, un-invoiced" Blog bot DAX Blogs 0 15.02.2012 07:13
Часовой пояс GMT +3, время: 04:22.
