Старый 16.04.2016, 09:17   #1
axinthefield: Microsoft Dynamics AX 2009/2012 – SQL Server 2008 R2/2012/2014 Configuration Check List for “Go-Live”
Источник: https://blogs.msdn.microsoft.com/axi...t-for-go-live/
Microsoft Dynamics AX 2009/2012 – SQL Server 2008 R2/2012/2014 Configuration Check List for “Go-Live” Server Level Settings Max Degree of Parallelism Best Practice is that the Max Degree of Parallelism on the production Dynamics AX SQL Server be set 1 Parallelism – When SQL is sent a SQL statement it runs it through the optimizer...
max degree of parallelism
CRM DE LA CREME! CRM 4.0 Disaster Recovery Blog bot Dynamics CRM: Blogs 2 26.02.2016 08:23
Dynamics AX Sustained Engineering: Now Supporting SQL Server 2014 Running on Microsoft Dynamics AX 2012 R2 CU7 and AX 2012 CU5 Blog bot DAX Blogs 0 03.07.2014 00:11
dynamics-ax: Dr. BI Tip: SQL Server 2008 R2 & Report Builder 3 for AX 2009 Blog bot DAX Blogs 0 31.03.2011 18:11
Часовой пояс GMT +3, время: 16:31.
