Старый 17.03.2016, 08:12   #1
X++: Using EDT array elements from Proxies or from the .NET Business Connector for AX
Источник: https://blogs.msdn.microsoft.com/x/2...nector-for-ax/
by Peter VilladsenDecember 2013   The Microsoft Dynamics AX 2012 system allows an individual table field, in any one record, to contain multiple values. Typically this is done by creating an extended data type (EDT) that is an array type, and then using the EDT as the type for a field in a table. The...
bojensen: Using Dynamics ‘AX .NET Business Connector’ to access Dynamics AX 4.0 from .NET world Blog bot DAX Blogs 0 12.08.2014 13:11
X++: Using EDT array elements from Proxies or from the .NET Business Connector for AX Blog bot DAX Blogs 0 12.12.2013 01:14
fed: Net requirements update in MRP Module and Working Set of MRP Blog bot DAX Blogs 14 08.05.2012 13:09
Inside Dynamics AX 4.0: Working with the .NET Business Connector Blog bot DAX Blogs 0 04.10.2007 05:15
Часовой пояс GMT +3, время: 12:02.
